Old 09-14-2020, 03:52 PM   #1
40larry
Default 1939 1940 1941 firewall wiring kidney shaped cover
Here are three different firewall wiring covers. The one on left is the commonly seen 1939-1940 cover. I believe the center picture is the 1941 cover with the wide openings for harness. The one on right has a flat top and i believe it is an early part for 1939. Has anyone seen one of these flat top covers or know anything about it? All three have identical positions for screws. Does anyone
40larry is offline   Reply With Quote
Old 09-14-2020, 05:07 PM   #2
Kube
Kube's Avatar
Default Re: 1939 1940 1941 firewall wiring kidney shaped cover
Larry, The flat one is early '39. However, I can no longer recall when the design change occurred. It was very early - that much I recall. It was done as you would suspect, to allow more room for the wires.
Old 09-14-2020, 07:17 PM   #3
mercurycyclone
The Early Ford V8 Clubs 1938 - 39 Ford Book page 4-31 states the part was revised 0n 10/28/38.
File Type: jpg 1AB71DC6-21AD-4CAE-B2C2-40DBBB34B3A5.jpg (37.7 KB, 38 views)
File Type: jpg 12660113-94E6-43D7-8450-6CF4EAEF9219.jpg (39.4 KB, 33 views)
mercurycyclone is offline   Reply With Quote
Old 09-15-2020, 07:13 AM   #4
rockfla
rockfla's Avatar
I wonder HOW the 39 Mercury's missed using them???
Old 09-15-2020, 10:41 AM   #5
40larry
Can anyone confirm that the center one is in fact 1941 and maybe 1942. Someone with an original car might be able to check for me. Thanks......40larry
Old 09-15-2020, 01:08 PM   #6
mercurycyclone
It might be 41 42 Ford Truck not passenger car cover. See attached 41 Ford Mercury has only two wire openings for passenger cars part number 11A-14600. 1942 - 47 has larger wire openings than the 41 Ford and is part number 21A-14600. Hope this helps.
File Type: jpg 55CE4479-5C92-4D5B-A267-91C66648D9C7.jpg (48.7 KB, 62 views)
Old 09-15-2020, 01:26 PM   #7
Fritz
Fritz's Avatar
The center one looks more like the one on my 41 1/2 ton pickup. Although mine is smooth on the top and does not have that indent by the top wire opening.
File Type: jpg 93EECC56-90F1-4413-9E8A-D099B2D6A6B5.jpg (39.4 KB, 64 views)
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 09-15-2020, 04:17 PM   #8
mercurycyclone
See attached.
File Type: jpg 29FFE1E4-6AB5-4635-B6ED-EB18C14BEA9E.jpg (51.7 KB, 111 views)
Old 09-15-2020, 06:09 PM   #9
mercurycyclone
Early 39 Mercury had the same problem as early 39 Ford. The Mercury wire cover part number was 99A-14600.
Old 09-16-2020, 11:12 AM   #10
40larry
Originally Posted by mercurycyclone View Post
See attached.
That still leaves the center one in my photo without a clear answer. it has all three large wire openings.
Old 09-16-2020, 11:57 AM   #11
40larry
Can someone confirm that the center one in my picture is the 21A-14600 that is called out for all 42-48 passenger cars. Does the 21A-14600 have two or three wire openings?
thanks 40larry
Old 09-16-2020, 12:03 PM   #12
rockfla
rockfla's Avatar
This is my 10/38 production, 39 Mercury and it has NO part you speak of????? OR at least in any of these pictures!!!! NOTE my above post as 39 Mercury NOT having one!!!!
Old 09-16-2020, 12:09 PM   #13
rockfla
rockfla's Avatar
thanks 40larry
Not sure IF it helps you Larry but this is the only shot I have of my 46 Tudor I had and the part you ask of......Looks like two!!!!
Old 09-16-2020, 12:12 PM   #14
rockfla
rockfla's Avatar
A closer scan
Old 09-16-2020, 06:20 PM   #15
mercurycyclone
See attached the cover pictured is off of a 1942 - 47 Ford Pickup.
File Type: jpg 7CFB7971-98FB-4A6A-B807-38151B214981.jpg (28.3 KB, 27 views)
Old 09-17-2020, 11:32 AM   #16
40larry
Thanks. That seems to answer the question. Your picture is same as my center cover pictured. It appears that the 21A cover only has two wire openings. So my center cover is the 1942 to 1947 pickup. If this cover fits the 42 to 47 pickup should there be a 21C-14600 listed in the parts book? Have you seen a 21C part number for a cover in any Ford parts book.
40larry
Old 09-17-2020, 11:38 AM   #17
40larry
The parts book calls out the 99A-14600 as used on the 1939 and 1940 Mercury.
Old 09-17-2020, 07:52 PM   #18
mercurycyclone
40 Larry I have attached a photo of all the cover styles I have at the moment so you can compare the differences. I do not have a 21A-14600 right now but it had only two wire holes and was correct for Ford and Mercury.
Rockfla if you look at the firewall on the engine compartment side below the voltage regulator where the wire harness from under the dash connects to the wire harness for the engine compartment you will see three small holes for the screws that hold the wire harness cover. I have had at least six 39 - 40 Mercury covers and all have had only two holes for the wire harness. Two of the covers were early and the balance later. Looking at all the covers you will see all have the same location for the screws. Hope this helps.
File Type: jpg 8731E111-AA05-4446-AA56-477E57EEE62B.jpg (51.0 KB, 79 views)
File Type: jpg C523F3D9-552E-4F1D-9CD4-B9DB349CC3E3.jpg (43.0 KB, 39 views)
Old 09-18-2020, 06:54 AM   #19
rockfla
rockfla's Avatar
Thanks, obviously mine is "missing" SO the hunt begins!!!! "IF" any of you posting here have one, I'm your man "EARLY" one that is!!!!
Old 09-18-2020, 08:01 AM   #20
rockfla
rockfla's Avatar
ALSO a fellow barner wanted me to post this picture for him as he couldn't asking for an "ID" which I believe is 41?????
