Old 07-30-2020, 08:32 AM   #1
Richard Lorenz
Default Manifold Gland Rings
These are the rings that go between the block and the manifolds. What experience or recommendations do you have?
Richard Lorenz is offline   Reply With Quote
Old 07-30-2020, 09:04 AM   #2
Conaway2
Conaway2's Avatar
Default Re: Manifold Gland Rings
I use them to help with alignment of the manifold to the block. If you cannot make them line up, its usually a sign of a warped manifold.
Conaway2 is offline   Reply With Quote
Old 07-30-2020, 09:06 AM   #3
Will N
Will N's Avatar
Over time, the rear of the exhaust manifold tends to droop downward due to the weight of the muffler pulling down on it while the manifold is near red-hot. The holes in the manifold and the exhaust ports in the block get out of alignment, and you can't use the gland rings any longer. It seems to work ok with just the gasket if you have the manifolds faces trued up with a mill.
Will N is offline   Reply With Quote
Old 07-30-2020, 09:58 AM   #4
katy
katy's Avatar
If you're going to put them in, check the width of the rings and the depth of the openings, to be sure that when they're in the gasket will be compressed to make a good seal.
Old 07-30-2020, 12:25 PM   #5
dmaxweb
dmaxweb's Avatar
They sometimes migrate to your muffler resulting in a new rattle.
dmaxweb is offline   Reply With Quote
Old 07-30-2020, 12:42 PM   #6
Mulletwagon
Mulletwagon's Avatar
X2 If they fit they are worth using.
Mulletwagon is offline   Reply With Quote
Old 07-30-2020, 12:56 PM   #7
Brentwood Bob
Watch this.https://m.youtube.com/watch?v=ylGWKvNvbmU
Should cover most of your concerns.
Brentwood Bob is online now   Reply With Quote
Old 07-30-2020, 01:52 PM   #8
Bob-A
Bob-A's Avatar
Question Re: Manifold Gland Rings
Last muffle change on my roadster. I found "7" gland rings rattling around
in the old muffler! The gland rings that the parts houses sell and I use. Are not the proper dimensions and are more of a generic better than nothing replacement. I believe the Judging Standards give what the proper size and make up of the original rings are. Is anybody making correct gland rings?
Bob-A
Bob-A is offline   Reply With Quote
Old 07-30-2020, 05:28 PM   #9
Mad Mac
I have found that the "nothing" option works really well. After buying the rings I got fed up with trying to make them fit and decided not to use them. No problems so far.
Mad Mac is offline   Reply With Quote
Old 07-30-2020, 05:52 PM   #10
dmaxweb
dmaxweb's Avatar
Forget the repro gland rings and get copper manifold gaskets from Bert's. Part A-9448-D Made in USA!
Old 07-30-2020, 07:56 PM   #11
Ruth
I have used these copper gaskets with the glands built in from MAC's. Part #: 28-24825-1
Ruth
Old 07-30-2020, 09:16 PM   #12
redmodelt
redmodelt's Avatar
Except for a short time in I think 1930 (and then on only a few engines) all Model A engines used them. If Ford did not think they were important he would not have used them. all the engines we do get them if they are ported for them.
Old 07-30-2020, 10:51 PM   #13
SteveB31
SteveB31's Avatar
Ford only used them in 1928. They are worthless in my opinion. Been fixing and driving Model A’s my whole life and never used them or needed them
SteveB31 is offline   Reply With Quote
Old 07-30-2020, 11:03 PM   #14
Karl
Karl's Avatar
I agree -found they made the job harder. Decent copper crush gaskets and clean milled faces and the jobs done
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 07-31-2020, 09:43 AM   #15
redmodelt
redmodelt's Avatar
If Ford only used then in 1928 then why are all the blocks and exhaust manifolds machined for them?
Old 07-31-2020, 09:52 AM   #16
Ruth
I have heard the same as redmodelt. And redmodelt makes a valid point. Why did they continue to machine the blocks and manifolds if only used in 1928?
Ruth
Old 07-31-2020, 09:56 AM   #17
fredski53
fredski53's Avatar
I love reading all the comments from the experts and how one tells you to use them and someone tells you they are not needed! ❤️ it!
fredski53 is offline   Reply With Quote
Old 07-31-2020, 10:03 AM   #18
Bob Bidonde
Bob Bidonde's Avatar
The original purpose of the gland rings, that are used only in the exhaust ports, is to prevent burnout of the manifold gaskets. The rings expand, so they need to have 1/16th gap when installed. If no gap, the rings will buckle and windup in the ports.
Bob Bidonde
Old 07-31-2020, 10:08 AM   #19
Purdy Swoft
Purdy Swoft's Avatar
I have had some gland rings to end up in the muffler , that's why I quit using them .
Old 07-31-2020, 11:05 AM   #20
alexiskai
alexiskai's Avatar
We could possibly distinguish here between "are gland rings needed" and "are gland rings helpful." My understanding is that they're helpful in preventing manifold drop and damage to the gasket from high-temp gases. However, if it is difficult or impractical to procure gland rings that are the correct size, or if the manifold has previously been resurfaced, such that there is no longer sufficient depth to permit the rings to be installed correctly, the benefit provided by the rings may not be enough to justify the cost of modifying the manifold/block or hunting for rings that are the correct size.
