Old 03-01-2021, 10:22 AM   #1
BillW810
BillW810's Avatar
Default '39 - '40 hood comparison
Can a '40 Standard hood be used on a '39 DeLuxe? Any differences in trim or mounting. I think the latches are different.
The hinge mounts on mine are bent and I'm not having success straightening them.
Thanks.
BillW810 is offline   Reply With Quote
Old 03-01-2021, 10:29 AM   #2
drolston
drolston's Avatar
Default Re: '39 - '40 hood comparison
Pretty sure you can purchase replacement hinge mechanisms.
Old 03-01-2021, 10:57 AM   #3
MuskegonFlatheadFan
MuskegonFlatheadFan's Avatar
They were different part numbers, so technically they are different. The cowls and fenders are shared, so that should work. Trim is completely different, so all holes would need to be addressed. I'm not sure on the grill fitment, they are different, but maybe that's just the style and not the actual shape where the hood mates.
MuskegonFlatheadFan is offline   Reply With Quote
Old 03-01-2021, 11:28 AM   #4
BillW810
BillW810's Avatar
I have new hinges. The problem is the mounts welded into the hood are bent.
Old 03-01-2021, 11:31 AM   #5
BillW810
BillW810's Avatar
Thanks that is what I thought. Even with the ,39 there is an early and late latch mechanism. They look a lot alike but with subtle differences.
I looked up the hinges they are the same for '39 and '40 so the mounts at least must be the same.
Bill
Old 03-01-2021, 07:17 PM   #6
Karl Wescott
Karl Wescott's Avatar
The shape of the stampings of the 1939 Deluxe and 1940 Standard are the same. The front of the 1939 Deluxe has cut-outs for trim mounting that the 1940 Standard does not, and of course the large trim spears are in different location. The 1939 Deluxe had two different hood latches, the later one will interchange with if it is not the same as the 1940 Standard.
Note that if you go with repro hinges, while the mounting plate is usually OK the arms are bent weird and will need to be reshaped so the hood will lift true and settle down in the back properly.
Karl Wescott is offline   Reply With Quote
Old 03-02-2021, 08:47 AM   #7
Automotive Stud
Automotive Stud's Avatar
Message 40fords on here, his name is Gary and he's right in Wilmington. He'll have whatever you need, original hinges, hood, and anything else for a '40. Anyone in the tri state area with a '40 should have him on speed dial.
Automotive Stud is offline   Reply With Quote
Old 03-03-2021, 09:13 AM   #8
Pete pa
I used a 40 standard hood on my 39 deluxe coupe and it fits perfect. I wanted to remove all the stainless, and the 40 hood has less holes to weld up that is why I used it.
The difference between the early and late 39 hoods are the hood latch support in the front of the hood but you can change the early for the late it bolts right in.
If you need a replacement hood let me know I may part with one of mine. I live near the Butler valley exit of the turnpike so you could come and check it out and compare it to yours. Let me know
Pete pa is offline   Reply With Quote
