Old 11-17-2020, 01:56 AM   #21
Tinker
Tinker's Avatar
Default Re: is it ok to run diluted antifreeze?
Depends on were you live. If you are in Canada I'd say not. But if you live in Texas. Sure. "Anti-freeze" it's in the name.
Old 11-17-2020, 02:10 AM   #22
Tinker
Tinker's Avatar
Next time you have your heads off rod out the block with a long screw driver or a wire. Flush it. Make sure the radiator is good. People used to drive these engines across the country.
