Old 11-18-2012, 09:44 PM   #21
Elcastor
Elcastor's Avatar
Default Re: Can a sticky cutout be repaired?
Originally Posted by Tom Wesenberg View Post
Cutouts aren't too bad to work on. I cut a hole in a block of wood to hold the cutout upside down. I use a very sharp thin chisel to split the spot welds, then the cover can be pried off. Once the cover is removed you can straighten the bent metal from using the chisel on it. Use compressed air to blow the metal specs off the top of the armature, where they like to collect due to the magnetism. File the contacts or sand them smooth, then set the open air gap to .020" and make sure when the contacts are closed that the top of the armature (magnetic coil) still has a thin air gap.
The cutout on the right and the bottom picture shows an original cutout and the quality it has over the left cheapo cutout.
The cover will fit tight and doesn't need to be soldered or spot welded to hold it in place.
How do you clean up the inside of a cutout so nicely as shown in these pictures?
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 11-18-2012, 09:52 PM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Can a sticky cutout be repaired? FOLLOWUP
I use the small wire brushes similar to a toothbrush, and compressed air. Actually the inside stays pretty clean, except sometimes fine metal grit collects on top of the electromagnet. It's easily blown away with compressed air.
Most of the repros I don't waste time trying to fix.
Old 11-18-2012, 10:02 PM   #23
700rpm
700rpm's Avatar
I put the diode cutout in and haven't had any problems since.
Ray Horton, Portland, OR
Old 11-18-2012, 10:35 PM   #24
Purdy Swoft
Purdy Swoft's Avatar
Good move !! Thanks for the follow up.
Old 11-18-2012, 11:25 PM   #25
Mike V. Florida
Mike V. Florida's Avatar
Tom, never having seen a cut out opened in person, could his problem be as simple as residual magnatism in the core of the relay?
Old 11-19-2012, 01:13 AM   #26
Tom Wesenberg
When the current flows backwards (generator not charging and contacts still closed) the magnetism is reversed and should open the contacts. Some of the cheap repros will burn at the contacts and stick closed. If the contacts aren't burned then I'd try adjusting the spring for a little more opening tension. Just don't make it too tight, because the contact should pull closed by 6 volts.
Old 11-19-2012, 10:51 AM   #27
marc hildebrant
marc hildebrant's Avatar
I currently have an alternator and did not pay much attention to the design of the cut-out and how it worked. I have to say that I'm impressed with the design of the cut-out. The use of two coils and the way that Ford designed a simple circuit to perform a complex function is quite impressive.
Note the way that he used the many turns with fine wire. Very nice enginering.... Magnetic fielded strength is related to the current and the number of turns around the pole piece. Many turns created a strong field that was balanced with the fine wire that reduced the current to just the right level to pull in the relay but not enough to hold it long.
Very clever.
Marc
marc hildebrant is offline   Reply With Quote
Old 11-19-2012, 11:55 AM   #28
SteveB31
SteveB31's Avatar
If any of you are needing a restored original cutout, we have a couple hundred of them, restored, tested, cadmium plated and ready to install for $65 each.
Steve Becker
Berts Model A Center
Denver, CO
[email protected]
SteveB31 is offline   Reply With Quote
Old 04-06-2013, 06:05 PM   #29
pyrodork
pyrodork's Avatar
Send a message via Yahoo to pyrodork
i know i'm posting on an old thread, but i just threw a diode in mine. what i'm wondering about is the paper insulation all over. mine was brittle and some did break away before and after the conversion.
the riveted bracket (the wire solder side) actually came off. i believe it was just the paper insulation holding it on, but i'm not positive. i was able to set it back into the remainder of the rivet holes, but i don't want it to short out after i install it.
also, the paper insulation underneath the cutout assembly. much of that was gone when i first took the cutout off to examine it.
i realize i can probably make something myself to replace these, but is there a recommended material? what points must i make sure to have insulated from the body? does anybody sell these things in a kit?
Current Classics:
1930 Ford Model A Tudor
1937 Plymouth P4 Deluxe 2-door touring sedan
1964 Ford Galaxie 500
Past Classics:
Early '30 Ford Model AA
1948 Dodge Deluxe 4-door sedan
1951 Studebaker Champion 2-door sedan
1988 Ford E-350XL Ambulance
pyrodork is offline   Reply With Quote
Old 04-06-2013, 07:38 PM   #30
Tom Wesenberg
I bought some small pieces of insulating board at ABC Electronics in Mpls, but it's a hit and miss thing. They didn't have any more the last few times I was in the store.
Old 04-06-2013, 11:37 PM   #31
tbirdtbird
This may help
from www.mcmaster.com
Ultra-Thin Flexible Paper Insulation
  • Temperature Range: -4° to 266° F
  • Heat Flow Rate (K-Factor):
    0.003" Thick: 0.15 @ 356° F
    0.015" Thick: 0.25 @ 356° F
  • Density:
    0.003" Thick: 87 lbs./cu. ft.
    0.015" Thick: 93 lbs./cu. ft.
  • Color: Off-white
Often used in high-humidity applications for its low-moisture absorption, this inorganic-material-based paper meets UL 94V0 5VA for flame retardance and can be used as a flame barrier.
Thick.Wd.Lg. Each0.003"36"24"9583T21$6.980.015"36"24"9583T2227.00
http://www.mcmaster.com/?m=true#elec...lation/=m7n5cd
'31 180A
tbirdtbird is offline   Reply With Quote
Old 04-08-2013, 01:14 AM   #32
pyrodork
pyrodork's Avatar
i just got the new bratton's catalog and saw that their diode comes with a kit that includes these gaskets, screws, etc. i'll do some checking around and report back.
Current Classics:
Past Classics:
Old 04-08-2013, 05:53 AM   #33
kwisor
kwisor's Avatar
hello
not sure if related but when i start my car the amp meter show no charging untill i start to drive then it will show charging if i incress the rpms it will not show charge till after i start to drive is the cut out sticking till i drive it
kevin
kwisor is offline   Reply With Quote
Old 04-08-2013, 04:06 PM   #34
pyrodork
pyrodork's Avatar
little dearborn doesn't sell any internal cutout parts. brattons only has the kit, which is $7.
would gasket material do the same job? or rubber from an old inner tube?
Current Classics:
Past Classics:
Old 04-09-2013, 12:10 PM   #35
pyrodork
pyrodork's Avatar
Originally Posted by kwisor View Post
hello
kevin
i haven't been able to drive my AA yet, but i'm going to assume that's normal. with the higher rpm's, the generator will be spinning faster and generating more power; thus charging the system.
i think the meters on modern vehicles have a wider range, and alternators are designed to work differently from generators. i'll bet that's partially why there's more significant electrical values in alternator cars versus generator cars.
Current Classics:
Past Classics:
Old 07-27-2017, 08:21 PM   #36
Jeff/Illinois
Jeff/Illinois's Avatar
Tom, is it possible to resurrect your pictures on this subject?? Evidently they have been blocked I wished to learn a bit more about fixing an original cutout.
Thank you.
Jeff/Illinois is offline   Reply With Quote
Old 07-27-2017, 09:52 PM   #37
Tom Wesenberg
Thank you.
Maybe it could be a winter project. That's a lot of pictures lost because of photosuck.
Old 07-27-2017, 10:04 PM   #38
1955cj5
1955cj5's Avatar
The pictures are still on photobucket...
It may take a while to find what you want though!
http://s118.photobucket.com/user/Tom...?sort=3&page=1
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 07-27-2017, 10:38 PM   #39
Tom Wesenberg
Wow, you're good. I haven't been able to get into photosuck for about 5 years.
Now, with there being 1400 pictures, is there an easy way for me to put them all on a card? Thanks
Old 07-27-2017, 10:51 PM   #40
1955cj5
1955cj5's Avatar
I wish I knew Tom.....I just googled your name with the word photobucket and there they were.....I really don't know if you can retrieve pictures from photobucket........
Lots of neat pictures by the way!
