Old 10-10-2020, 11:38 AM   #1
rawlir
Default 46&47 Ford Conventional trucks Wire harness
Hello,
I have 2 46 & 2 47 Ford Conventional trucks, (not COE's)
3 of the 4 have the 1.5 inch (+or-) firewall hole into the cab in front of the driver for the instrument panel in exactly the same location. The 4th, (the one i am starting to install the wire harness) is 3 inches or so directly to the right of the others, anyone seen this?
I am trying to determine if that offset is going to cause an installation problem with the wire harness installation/placement? I bought my wire harness from Tyree Harris on the East Coast....
If anyone has seen that hole where i am talking about would very much appreciate hearing from you as to what you may know of that.....
Thank you!
Rick 425 766 7408 [email protected]
rawlir is offline   Reply With Quote
Old 10-10-2020, 04:06 PM   #2
Doublepumper
Doublepumper's Avatar
Default Re: 46&47 Ford Conventional trucks Wire harness
rawlir......email inbound.
Doublepumper is offline   Reply With Quote
