Old 10-06-2020, 08:02 AM   #1
harleycontracter
Default Tips Removing slight pitting
I bought a chrome roadster windshield probably from the 60's . Had slight rust pits . Any thoughts on how to clean it up a bit. It's very slight
harleycontracter is offline   Reply With Quote
Old 10-06-2020, 08:11 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Tips Removing slight pitting
Very fine steel wool.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-06-2020, 09:56 AM   #3
Charlville
Charlville's Avatar
As per @chrs1961815 and if you are not having much luck add a little Autosol to the steel wool
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 10-06-2020, 10:08 AM   #4
rotorwrench
rotorwrench's Avatar
More polishing is about all you can do for plated surfaces. It can be polished through the chrome so a person doesn't want to get carried away if using buff wheels.
Old 10-06-2020, 10:26 AM   #5
Will N
Will N's Avatar
Try rubbing the chrome with aluminum foil. http://www.slipperyrockgazette.net/i...fm/pageId/1948
Will N is offline   Reply With Quote
Old 10-06-2020, 10:28 AM   #6
Charlville
Charlville's Avatar
@Will N yes I've had a bit of success with foil
Kevin Flood
West Berkshire UK
Old 10-06-2020, 12:03 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
When I first started working the used car lot had a jar of mercury, the bad spot war treated with mercury to make it look okay
Old 10-06-2020, 12:09 PM   #8
Bruce_MO
Tin foil dipped in Pepsi or Coke... phosphoric acid helps
Bruce_MO is offline   Reply With Quote
