09-23-2020, 10:17 AM | #1 |
Stromberg carbs
Have a intake that set up to run 4 carbs
Do you run all 4 or just 2 and use linkage to run the other ones |
09-23-2020, 11:30 AM | #2 |
Re: Stromberg carbs
Given the design of most 4-carb intakes, they are designed to run all four in unison. Unless you have a larger cubic inch engine and are into real racing, you might be best off with four of the smaller 81 Strombergs.
09-23-2020, 11:35 AM | #3 |
Re: Stromberg carbs
And that can get real expensive.
09-23-2020, 11:56 AM | #4 |
Re: Stromberg carbs
It's a inline 6 301 cubic inch with a 588 camshaft for a hot rod
09-23-2020, 12:40 PM | #5 |
Re: Stromberg carbs
In your case, you should be able to run 2, with the other 2 on a progressive linkage.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
09-23-2020, 02:10 PM | #6 |
Re: Stromberg carbs
09-23-2020, 02:57 PM | #7 |
Re: Stromberg carbs
Chevy 292 +.060 custom pistions lump ports close to 10to1 compression custom intake 588 intake 581 exhaust 234 intake 234 exhaust at .050 lob Sep 112
09-23-2020, 03:15 PM | #8 |
Re: Stromberg carbs
OK. That explains it. (Modern stuff.) Sounds healthy, though. It might run OK progressive, but I bet straight would be better. The only time I ran 4 97's was on the 331 Hemi in my racecar (straight linkage, of course). It ran great and was quite fast, but for some reason, I had to go through the carbs every year. I finally had enough of that and went to two large-base 2G's on a different manifold; it ran about as good and the carburetors are completely trouble free. (One of the guys I raced with ran a 320 ci Buick straight eight with 5 97's (straight linkage as well.)
When I had the first setup, I ran across an article someplace (maybe on the H.A.M.B.) that explained how to properly set up 4 in a row with a straight linkage for the street. Maybe I can find again it if you're interested. |
09-23-2020, 03:41 PM | #9 |
Re: Stromberg carbs
The gm carbs are good for shure but they don't look as good as the older ones
09-23-2020, 06:37 PM | #10 |
Re: Stromberg carbs
How about three Carter YH side draft carburetors, like the early Corvettes?
Also used on turbocharged Corvairs and some Nash, I think. Last edited by Zeke3; 09-23-2020 at 06:39 PM. Reason: Added info. |
