Old 07-30-2020, 02:43 PM   #1
Tveditr
Default Voltage Regulator??
Anyone use a voltage regulator in their Model A?? If so what regulator and why? I am replacing the wiring harness and the awful wiring job on my 30 Coupe. It has a lot of stuff wired to a voltage regulator n the firewall and I’m wondering if that needs to be there.
Tveditr is offline   Reply With Quote
Old 07-30-2020, 02:52 PM   #2
Bob C
Default Re: Voltage Regulator??
What generator are you running, two brush or three?
How about a picture.
Old 07-30-2020, 03:34 PM   #3
Patrick L.
Patrick L.'s Avatar
It sounds like you're using a later style 2 brush generator. If so, then a regulator needs to be mounted somewhere.
If you want to install an original type 3 brush generator then you don't need a regulator, just a cutout.
Old 07-30-2020, 04:33 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
I use the Fun Projects voltage regulator that takes the place of the cut out . The original cut out doesn't give voltage regulation .
Old 07-30-2020, 08:10 PM   #5
Sunnybrook Farm
Sunnybrook Farm's Avatar
Three brush delco remy uses a 2 point regulator which functions like a cut out and the 2 brush uses the 3 point regulator. Tractors used the same set up and there are documents and videos on line that show how it connects.
Sunnybrook Farm is offline   Reply With Quote
Old 07-30-2020, 08:34 PM   #6
Tveditr
How do you determine whether your generator is a two brush or three brush generator??
Old 07-30-2020, 09:04 PM   #7
David R.
Pull the band off the back end and you should be able to see.
David R. is offline   Reply With Quote
Old 07-30-2020, 10:29 PM   #8
Drive Shaft Dave
I use Tom Wesenberg voltage reg, his is fool proof ,if the generator should go open circuit the voltage will remain low, not going into a self destruct high voltage runaway.
Drive Shaft Dave is offline   Reply With Quote
Old 07-31-2020, 08:20 AM   #9
Badpuppy
One post (ARM) on top - three brush. Two posts, (GEN,FIELD) - two brush.
Badpuppy is offline   Reply With Quote
Thread Tools
Display Modes
