05-17-2020, 10:36 PM | #1 |
Springtime maintenance
Was able to get out and do some spring time maintenance. I gas primed the 38, but just pulled the choke on the 36 after 5 months of sitting.
Lube done. Diff checked. Tire air.... Only thing to check is the transmission oil level and an engine oil change. Be well! |
05-18-2020, 09:55 AM | #2 |
Re: Springtime maintenance
how about the mini bike and stationary engine, those are next?
05-18-2020, 02:31 PM | #3 |
Don't forget to fill steering gear
05-19-2020, 09:39 PM | #4 |
Dig that little Indian type pit bike. Fun to tool around from place to place. Started the 1927 1.5hp mccormick deering up for a few hours a couple weeks ago. Just let it bang out for a while and boil the water tank. All is well greased and oiled.... no need in changing it, just feed it, there are no lubrication tanks. Hope you are well Cas3. . |
05-19-2020, 10:10 PM | #5 |
05-19-2020, 10:39 PM | #6 |
05-20-2020, 12:18 AM | #7 |
I have the same hp model but after deering left early on. 1940 IH, you see them at car shows making ice cream (technically a throttler)
1940s 1.5hp ih. Basically a one cylinder ohv motor. Coined, the iron pig, for obvious reasons. https://www.youtube.com/watch?v=8PFtVpFM37w . Last edited by Tinker; 05-20-2020 at 11:07 AM. |
Thread Tools | |
Display Modes | |
