12-16-2019, 08:37 PM | #1 |
Welding question
I used my pro-mig Lincoln electric welder to install a patch panel on
my model a the other day. It has been a long time since I used this and I forgot to hook the bottle up to it. It is 75% percent argon and 25% carbon dioxde up. Question is should I start over with welding the panel again[LIST] Thank you for your help !! |
12-16-2019, 08:42 PM | #2 |
Re: Welding question
the gas acts as a shield, without it the weld may look terrible and not be sound.
12-16-2019, 09:33 PM | #3 |
My guess is that you already have the answer to your question. Go with it and you will be happier in the long run.
12-16-2019, 09:36 PM | #4 |
I think I would grind the welds and have a look .
Dennis in Kelsey ca |
12-16-2019, 09:42 PM | #5 |
Without the Ar/CO2, the welds must look bad and have no strength. Grinding them will show lots of pin holes.
12-17-2019, 08:10 AM | #6 |
Having said that I would follow the #4 post. Then re-weld as necessary, be careful with the heat. |
12-17-2019, 08:49 AM | #7 |
agree with Birdman. You may have flux wire in the machine, it should have welded and looked like shit with the gas off. Check your wire spool.
12-17-2019, 09:31 AM | #8 |
Gosh I love my MIG (Lincoln SP135) The sound when you get it "right" (frying eggs) is like music to my ears.
Want to re-learn use of a MIG? Try welding aluminum using the special "kit" and pure argon. It works - kind of. Joe K
Shudda kept the horse. |
12-17-2019, 12:15 PM | #9 | |
You may even see through the weld! Weld with porosity is NOT a good weld.. The fellow that did the welding,..Look up the word porosity. |
12-17-2019, 03:41 PM | #10 |
Welding aluminum with a mig just takes practice. I once welded two pop cans together with one.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
12-18-2019, 12:12 AM | #11 |
Pin holes and bubbles galore when I forget to turn on the gas. It is very ugly without the gas and you can just break off a bolt welded to a piece of strap with it....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-18-2019, 05:16 PM | #12 |
It took me awhile but decided to do it YOUR way and the best part the welds are a lot better !!!!!!!!!!!!!!! I think five cars may be to much at 72 ?
? Thank you all very much !! Last edited by keyswitch1; 12-18-2019 at 05:18 PM. Reason: Correction |
