Old 08-21-2019, 09:25 PM   #1
braol
braol's Avatar
Default Motor Suddenly Stuck
This is really weird: I've been driving my '31 Model A all summer. Last time was 4 days ago. I get in the car tonight and it started to turn over for a split second and then stopped. I thought the battery was dead but light are good. I then, with the brake off, I then tried to rock the car in gear with the plugs out and the engine won't spin. I can't hand crank the engine either...like it's seized. I never heard of a perfectly fine running car suddenly suffer a seized engine. the last time I drove it I literally drove around the block and then home, not like I was on some long road trip and melted the engine down without oil in it or something. Any ideas?????
"I have not yet begun to defile myself."
-Doc Holliday
'31 Tudor, '69 F100, '66 Mustang, '11 Ford Flex
braol is offline   Reply With Quote
Old 08-21-2019, 09:32 PM   #2
Blue-Truck-Nut
Blue-Truck-Nut's Avatar
Default Re: Motor Suddenly Stuck
Check and see if the starter is hung in. Unbolt the starter, you may hear a big snap as you loosen the bolts, which would be the Bendix returning. Or it could be a bad Bendix. Either way, that's what I would check next.
Sent from my E6810 using Tapatalk
Blue-Truck-Nut is offline   Reply With Quote
Old 08-21-2019, 09:33 PM   #3
chrs1961815
chrs1961815's Avatar
Sounds like your starter bendix got jammed, a fairly common occurence with these cars. What I was taught to do was to put the car in 3rd gear and push from the back to unjam it which has worked for me.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-21-2019, 09:50 PM   #4
redmodelt
redmodelt's Avatar
My 48 F2 does it sometimes and it's a beast to get rocking to pop the bendix.
Old 08-22-2019, 07:40 AM   #5
braol
braol's Avatar
Ok, before I break something let me make sure: push it from the BACK? Just making sure before I do something stupid...
-Doc Holliday
Old 08-22-2019, 07:47 AM   #6
rocket1
I never had any luck rocking the car to release the stuck bendix,If I had the problem I would back out the three bolts and kick the starter and you would hear a loud snap.I don't thing I can lift my leg that high anymore.
rocket1 is offline   Reply With Quote
Old 08-22-2019, 09:39 AM   #7
braol
braol's Avatar
I will update this evening/tomorrow on my success or failure. It HAS to be the starter. If not, I know what I'll be doing this Fall...engine pull. Eeeek.
-Doc Holliday
Old 08-22-2019, 09:49 AM   #8
Benson
Benson's Avatar
Once you get starter loose look closely at the shaft and check to be sure that it is not bent.
A bent shaft will be more likely to hang up in the future.
Benson is offline   Reply With Quote
Old 08-22-2019, 10:01 AM   #9
Purdy Swoft
Purdy Swoft's Avatar
I would remove the Bendix and spin the starter . If the armature is a blur when it spins the shaft is bent .
Old 08-22-2019, 10:46 AM   #10
braol
braol's Avatar
Will do. Thanks for the input.
-Doc Holliday
Old 08-22-2019, 01:39 PM   #11
1931 flamingo
1931 flamingo's Avatar
BEFORE you remove the starter, "bang" it with a hammer. Might free it up. JMO and has worked for me.
Paul in CT
Old 08-22-2019, 01:53 PM   #12
braol
braol's Avatar
Paul in CT
Alright!! Actually fixing it with a hammer would be great...how often can you REALLY fix something by just banging on it with a hammer?!
-Doc Holliday
Old 08-22-2019, 04:36 PM   #13
jm29henry
jm29henry's Avatar
Great news thanks for the update
jm29henry is offline   Reply With Quote
Old 08-22-2019, 05:28 PM   #14
1931 flamingo
It won't "fix" it but it will get you running or off to the side of the road.
Paul in CT
Old 08-22-2019, 06:13 PM   #15
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Do not push it forward. That will just jam it more or break something. Push the car back and don’t bang on anything.
Jacksonlll is offline   Reply With Quote
Old 08-22-2019, 06:46 PM   #16
tuneman
tuneman's Avatar
I put mine in 2nd gear and get a friend in front and me in back and rock it back and forth hard and it pops right back , get in and start it up. dont be afraid to rock it hard. take keys out of car !!!!!
tuneman is offline   Reply With Quote
Old 08-22-2019, 10:58 PM   #17
Drive Shaft Dave
This is one of those times when a block of wood and a very large whammer is your friend
I had one stuck so tight that i had to take out the three bolts , then wail on it, the all of a sudden sproing! Rocking the car wouldn't budge it.
Drive Shaft Dave is offline   Reply With Quote
Old 08-23-2019, 07:06 AM   #18
braol
braol's Avatar
Closure: The hammer wouldn't do it and neither would rocking the car. I removed the starter bolts (and it was still wedged in there), whacked on it again with the hammer, and finally resorted to rocking both the car and the unbolted starter. Finally it went SNAP and I was on the road again. As the kids were clamouring for ice cream and a Model A ride I deferred the starter shaft checks until next weekend.
Thanks ALL for the comments and tips.
-Doc Holliday
Old 08-23-2019, 07:18 AM   #19
chap52
chap52's Avatar
Great post. Thanks for sharing the complete adventure. Chap
chap52 is offline   Reply With Quote
