Old 01-14-2019, 12:08 AM   #1
Tim Warren
Default Turn signals: ground or isolate terminal block
I am installing a turn signal in my 31 TS. Can I mount the terminal block that all the wires will feed in to and out of on an inside panel (metal) or does it have to be insulated from grounding? Thank you in advance.
Tim Warren is offline   Reply With Quote
Old 01-14-2019, 12:14 AM   #2
Drive Shaft Dave
Default Re: Turn signals: ground or isolate terminal block
It would have to be insulated.
Drive Shaft Dave is offline   Reply With Quote
Old 01-14-2019, 04:28 AM   #3
jw hash
jw hash's Avatar
there is some nice turn signal set ups that are pos ground. and pretty easy to install Snyder`s has one that I installed years ago in my Victoria it is NOT self cancelling. one of my buddies show the set up he installed, it IS self cancelling and with four ways built in. it is made by Electro-Tech phone # 763 780 2861 Model # TSSWA4 it is real easy to install and it works great,
jw hash is offline   Reply With Quote
