Old 08-14-2018, 05:35 PM   #1
cfrye002
Default 1935 Ford 5 Window Paint
I have 1935 5 Window coupe, I would estimate the original paint on the body at 80%. All 4 fenders need body work and painted no question. My question is should the body just be touched up and match fenders as close as possible? Or repaint the entire car? I understand there are alot of factors, but what in terms of value and best practice for restoration would be the best route? Pics for reference.
Sent from my iPad using Tapatalk
cfrye002 is offline   Reply With Quote
Old 08-14-2018, 05:44 PM   #2
34fivewindow
34fivewindow's Avatar
Default Re: 1935 Ford 5 Window Paint
I like the car as is now.
34fivewindow is offline   Reply With Quote
Old 08-14-2018, 06:10 PM   #3
flatford8
flatford8's Avatar
They’re only original once.....keep what you can that’s original........repair the brakes, steering, fuel and electrical....then have a blast driving it!......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 08-14-2018, 06:35 PM   #4
jrvariel48
jrvariel48's Avatar
Originally Posted by flatford8 View Post
they’re only original once.....keep what you can that’s original........repair the brakes, steering, fuel and electrical....then have a blast driving it!......mark
ditto!!!
jrvariel48 is offline   Reply With Quote
Old 08-14-2018, 10:15 PM   #5
JSeery
JSeery's Avatar
I like the look of the original paint.
Old 08-15-2018, 02:20 AM   #6
Jay in Mass
From what I see, the black paint looks good. After doing the body work including the fenders, I would touch up the body and paint the fenders off the car then reinstall them.
Jay in Mass is offline   Reply With Quote
Old 08-15-2018, 04:24 AM   #7
FlatheadTed
FlatheadTed's Avatar
The dents that are there show its history ,any car like that that turns up to car shows will get people around like bees to a honey pot ,it depends whether you can stand the patina ,paint the left fenders only first with a reddish Maroon primer ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-15-2018, 10:23 AM   #8
Heard
Heard's Avatar
Ted- not being a painter, educate me on the color of the primer. Why reddish maroon?
Tanks,
Heard
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 08-15-2018, 05:58 PM   #9
FlatheadTed
Heard as far as I know the primer they used was a reddish colour,/oxide I have some engine tins here that have this primmer on ,as the paint ages and you get rub through ,this looks good ,Ted
Old 08-15-2018, 10:46 PM   #10
GB SISSON
GB SISSON's Avatar
What Ted (and everybody else) said.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 08-16-2018, 08:02 AM   #11
V8COOPMAN
V8COOPMAN's Avatar
Thanks,
Heard
Not being a 'painter' myself, I've run into this same situation over the years while squirting my own paint. A couple of quotes below from the H.A.M.B. explain the biggest reason far better than I could have put into my own words. DD
" Any color primer will work but you will need to apply more paint the more contrast there is between colors."
"A primary reason to use like-colored primers is reduce the amount of paint needed to for complete coverage. When just learning to paint, I made the mistake of using a light primer on a section of a truck bed when I ran out of dark primer. When I painted the truck, the entire bed had the same number of coats. However, when out in the light, there was a significant lightening of the paint where the light primer was used."
Click Links Below __
T5 W/TORQUE TUBE
Old 08-16-2018, 12:03 PM   #12
SUHRsc
SUHRsc's Avatar
Great looking car! Do you have any photos of it all together before you started? I have a 35 5w also but my old black paint isnt anywhere near as good. I always like to see others without whitewalls tires.
Zach
-WANTED-
Pre-War Speed Equipment
Davies or Morrison Intake Manifold
77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads
SUHRsc is offline   Reply With Quote
Old 08-16-2018, 06:46 PM   #13
cfrye002
Thanks for all the responses, actually its the dearborn blue color, just bad lighting in the shop. I do not have any pictures of it completely assembled that are digital, grandfather bought it in 1952, sat in garage till 1996 him and i started in it and got it that far. Just started back on it a month ago!, So onward and upward, we have it running and rewired, inside torn out, ready to repaint inside!
