07-08-2018, 05:18 PM | #1 |
Crab Distributors
Are there any differences in crab distributors when using single or two piece caps ? 46-48
07-08-2018, 05:33 PM | #2 |
Re: Crab Distributors
07-08-2018, 11:23 PM | #3 |
And the '46-'47 caps are a lot harder to install new wires on, but they are more water resistant (or so they say).
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
07-09-2018, 11:18 AM | #4 |
I would agree that those two cap jobs must be a Bear. Just took my off last week and noticed a couple wires had pulled loose from the cap and not much room to play with to get them back where they belong . Do ya'll think it would be better to change to a single cap and save frustration and easier to work on down the road ?
07-09-2018, 02:09 PM | #5 |
I'm running a 59ab in my '38 so I changed mine to a crab. It's easier to work on and I like the looks.
07-09-2018, 02:23 PM | #6 |
07-09-2018, 02:51 PM | #7 |
The shape of the cap is what earned it the crab nickname. The distributors are basically the same. The pancake V cap was a war time necessity to keep the water & other crud out. It stayed in production after the war. The bale can easily be removed and spring clips installed.
The crab cap utilizes a gasket to help keep the moisture at bay. |
07-09-2018, 07:45 PM | #8 |
In 20 plus years of driving, my crab distributor has never been a problem in the rain. And I have been in some VERY heavy rainfalls.
07-10-2018, 05:43 AM | #9 |
I guess after reading folks comments, I will change over to a simpler cap. It's not like I'm headed to Louisiana to drive across Lake Pontratrain in a rainstorm ! Thanks guys for the input.
07-10-2018, 07:47 AM | #10 |
So, to convert a conventional 1948 dist to a crab, all you need to do is purchase a crab cap and rotor and the spring clips? Nothing else?
Matt 24:36-41 |
07-10-2018, 08:25 AM | #11 |
Sounds good, I'm ordering from Joe's Antique parts at the moment.
07-10-2018, 08:31 AM | #12 |
07-10-2018, 09:28 AM | #13 |
You will also need nine rubber boots for the high tension leads where they fit onto the crab cap and the cap gasket to seal out water between the cap and distributer housing. Regards, Kevin.
07-10-2018, 10:53 AM | #14 |
The spring clips require what are refered to as split rivets to hold them on so those would also be needed.
07-10-2018, 11:05 AM | #15 |
The spring clips and split rivets are available as a kit. I got some from Macs, I would imagine other suppliers have them too.
Mart. |
07-10-2018, 02:35 PM | #16 | |
I suppose Macs charged about 15 bucks to ship those parts...ha ha....just kidding...
Matt 24:36-41 |
07-10-2018, 03:57 PM | #17 |
Gasket for cap .....
"I can't cry as long as I know the Lord has risen " |
07-10-2018, 04:55 PM | #18 |
07-10-2018, 06:21 PM | #19 |
07-10-2018, 06:47 PM | #20 |
I too have never seen a gasket for a crab cap. Would like one though. But.... Snapping the clips is hard enough already. What to do?
