10-11-2016, 12:15 PM | #1 |
A question about original shocks.
Were the original Houdaille shocks all marked CW/CCW? If not, is there another way to determine which corner they go on the frame?
10-11-2016, 12:20 PM | #2 |
Re: A question about original shocks.
You Connect the shock arm to the shock and you know where to install them.
10-11-2016, 12:36 PM | #3 |
Ray,
The cut out on the shaft for the shock arm bolt will be to the back side on the front shocks and to the rear on the back shocks; actually the left front and the right rear are the same and right front and left rear are the same. Ron |
10-11-2016, 03:28 PM | #4 |
Thanks guys. Both answers make sense. I was looking at an original on the bench, so I had limited reference.
10-11-2016, 03:52 PM | #5 |
The Stipe shock are/were made with internals that work exactly the samy was as originals. The others sold are newly designed internals.
10-11-2016, 05:43 PM | #6 |
