Old 08-18-2016, 02:24 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default Should I Use Water or Antifreeze Coolant?
Just in case you are on the fence as to using plain water, maybe this picture will help you decide.
Nothing like plain water to destroy a nice engine block and head.
Rusty water also destroys water pump seals and bearings/bushings.
Old 08-18-2016, 02:33 PM   #2
JD 1931
JD 1931's Avatar
Default Re: Should I Use Water or Antifreeze Coolant?
I have always used 50/50 antifreeze ,no problem with it............
JD 1931 is offline   Reply With Quote
Old 08-18-2016, 02:42 PM   #3
CarlG
CarlG's Avatar
The only time I would use plain water is to check for leaks. When no leaks are found, Then drain & replace with 50/50 antifreeze.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-18-2016, 02:50 PM   #4
ronn
water is thicker then antifreeze, so leaks are more readily detected with antifreeze.
at least that's what Ive found................
Old 08-18-2016, 03:02 PM   #5
JOHN CT
JOHN CT's Avatar
What kind of any freeze are you using? Are you mixing it yourself? Or are you buying the 50-50 Mix.
This year is going to be the first time I'll be leaving my model a in a nonheated garage. The winters here can 0-20 below I figure I ask you cuz being from Alaska you see much colder temperatures. Things like this happens when we love our hobby and we begin to collect more than one car.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 08-18-2016, 03:13 PM   #6
CarlG
CarlG's Avatar
Originally Posted by JOHN CT View Post
What kind of any freeze are you using? Are you mixing it yourself? Or are you buying the 50-50 Mix..
I only use water first to catch 90% of the leaks (if any). Saves antifreeze if there is a leak detected
I use the pre-mix 50/50. -- Prestone or Peak. (Whatever Costco or Sam's has)
Alaskan A's
Old 08-18-2016, 03:46 PM   #7
tbirdtbird
Tom, you take the fun out of everything......
now there won't be any more antifreeze wars
i am sure some Evaporust would have got that out
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-18-2016, 03:54 PM   #8
C26Pinelake
Guess what Tom? What you say and demonstrate makes good sense but nobody is going to change. That is just the way Barners are ! Wayne
C26Pinelake is offline   Reply With Quote
Old 08-18-2016, 04:23 PM   #9
Mitch//pa
Yes but water is cheaper
Old 08-18-2016, 05:01 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
Has anyone tried Star Brite Star-Cool Premium Synthetic PG Engine Coolant? Biodegradable, Non-Toxic. just wondering how it works. http://www.starbrite.com/item/starco...coolant-464-oz
Old 08-18-2016, 06:27 PM   #11
ped58
ped58's Avatar
Is that a 5 cylinder model "A" block?
ped58 is offline   Reply With Quote
Old 08-18-2016, 06:55 PM   #12
tbirdtbird
haha George Miller added 2 cylinders....if anyone could, it would be him
'31 180A
Old 08-18-2016, 07:03 PM   #13
Tom Wesenberg
Actually it's from a 1948 Studebaker Champion, and it's being turned into a cutaway engine.
Old 08-19-2016, 04:10 AM   #14
Tom Wesenberg
I have an idea that's what the rear of my block looked like in the spare temporary engine I installed in my 28. Even after several flushings and the 30 day vinegar treatment I'm still filtering out bits of rust. I made a cone shaped filter out of bug screen and folded a lip in the large end to catch the rust chunks. I'll take a picture of it the next time I remove it for cleaning.
Old 08-19-2016, 07:27 AM   #15
H. L. Chauvin
Hi Tom,
Nothing like actual experience vs. reading what others recommend.
Thanks for this engine photo which demonstrates the true results of past Model A Forum recommendations for using plain water for coolant.
As one can witness, over time, plain water for coolant is an excellent way to attack a cast iron cooling system which eventually leads to major clogged radiator problems, overheating, and increased engine wear.
Many will continue to use plain water for coolant ....... but, like continued tobacco use & cigarette use ....... it just takes quiet a bit more time for a modern day informed idiot to cultivate his own full blown lung cancer.
H. L. Chauvin is offline   Reply With Quote
Old 08-19-2016, 07:39 AM   #16
updraught
updraught's Avatar
Was it in a boat?
updraught is offline   Reply With Quote
Old 08-19-2016, 07:45 AM   #17
Tom Wesenberg
Originally Posted by updraught View Post
Was it in a boat?
No, but the owner said it's too bad to rebuild, so he's going to make a cutaway on 3 cylinders and run it on 3 for very short periods.
Old 08-19-2016, 07:47 AM   #18
C26Pinelake
Originally Posted by H. L. Chauvin View Post
Hi Tom,
A wise man has spoken! Wayne.
Old 08-19-2016, 08:00 AM   #19
updraught
updraught's Avatar
I can see why you drink Coke.
Old 08-19-2016, 08:30 AM   #20
leo
leo's Avatar
I would say that it is kind of hard to determine what any combination of water, antifreeze or etc. has on your engine block unless you can examine the inside walls.....
leo is offline   Reply With Quote
