Old 02-08-2020, 07:10 AM   #1
barnnone51
Default 1931 Fenders on RPU
Trying to put a RPU Together with fenders and running boards .I do have a set
of 31s off a Sedan. Or what would be the correct ones. Thanks
barnnone51 is offline   Reply With Quote
Old 02-08-2020, 08:20 AM   #2
kenparker
kenparker's Avatar
Default Re: 1931 Fenders on RPU
assuming your RPU ia a 30 or 31, the 31 fenders off a sedan will not fit. You wil need fenders off a 30 or 31 RPU, PU, Roadster or Coupe
kenparker is offline   Reply With Quote
Old 02-08-2020, 08:28 AM   #3
Keith True
Keith True's Avatar
The fronts will fit,as long as your pickup is also a 30-31.The splash aprons are different between the 30-31,but if used as a whole they will fit just fine.The rears are different.The difference is night and day on the rears.
Old 02-08-2020, 10:56 AM   #4
barnnone51
Thanks for the info .. Back to the drawing board..
Old 02-08-2020, 11:07 AM   #5
Purdy Swoft
Purdy Swoft's Avatar
The rear pickup rear fenders are wider than sedan fenders .
Old 02-08-2020, 01:56 PM   #6
Charlie Stephens
You should have added "if the '31 has a wide bed". If the '31 has the narrow bed the fenders are the same as coupe, roadster.
Charlie Stephens
Old 02-09-2020, 08:27 AM   #7
barnnone51
So I am good up to the end of the splash aprons with the 31 body?
Keith True mentioned the splash aprons will work if used as a whole. What does that mean?
Old 02-09-2020, 09:40 AM   #8
JRrev
JRrev's Avatar
Keith means if you have the '31 front fender and its long apron or the '30 front fender with its short apron that makes either whole. FWIW the '30 front fender has a short apron "tip" that's spot welded into the fender and therefore uses a separate short running board apron. The '31 doesn't have that "tip" so therefore the longer apron nests in that void.
JRrev is offline   Reply With Quote
