02-07-2020, 09:24 AM | #61 | |
Re: So much for Irish Spring and Dryer Sheets.....
02-07-2020, 12:26 PM | #62 |
Did Say NOT a good idea w pets! Either antifreeze or Mouse bait will make pets sick or worse!
Nomad |
02-07-2020, 12:55 PM | #63 |
There is no poison that selectively kills only rodents. All animals in the food chain are at risk, including animals that eat the poisoned animals.
Alan |
02-07-2020, 08:31 PM | #64 |
Hawks, owls, eagles, minks... snap trap them mice. No worries there will always be more mice. Outside of roaches they will outlive us all.
Bucket method where it traps the mice with antifreeze is fine. Straight poison is bad. There is no benefit to poisoning mice or rats. They either smell your shop up for months when they die in the wall or they could poison something else. I've never had an issue seeing a rodent and putting a snap trap out with peanut-butter and not getting it the next day. Just keep traps loaded with bait. . Last edited by Tinker; 02-07-2020 at 08:43 PM. |
02-08-2020, 07:09 AM | #65 |
It's funny as hell to see all the replies to my post ! The little buggers draw a lot of interest for sure. Someone mentioned moth balls and I've used them too, but no luck there either.
Thx....Mike |
02-08-2020, 07:29 AM | #66 |
02-08-2020, 09:25 AM | #67 | |
Had them getting in a kitchen cabinet once , they were so small the trap caught them by tail and back legs . |
02-10-2020, 03:47 AM | #68 |
My shop is located next to pasture land and we get them big fng rats! Made the mistake of leaving the garage door open recently and walked in there later that night after I closed the door and me and the rat met, later that night I put two sticky pads down w/peanut butter, one was over turned the next day and we never found the other one or the dead rat? Did find some fur but nothing else, we have 3 cars stored in that shop, plus my zero turn and a lot of stuff/parts in boxes, always leery of mice and rats.
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
02-10-2020, 12:09 PM | #69 |
you just need to train them a bit, then its not so bad having them around.https://www.youtube.com/watch?v=CIc-Eeh7IUY
02-10-2020, 01:47 PM | #70 |
That’s funny, who’da thunk. Maybe it’s a Pack Rat and the plastic container is his nest
Nomad |
02-11-2020, 12:36 PM | #71 | |
ditto on the Tomcat bait. I wiped out the mice population in my house and garage and have seen no signs in over a year. i check on the blocks I've put around and not even a nibble since I wiped them out.
glenn Quote:
02-12-2020, 07:32 PM | #72 |
warning on sticky traps * * if you don't nail them to something lots heavier than the rat they will flip and flop all over your shop and leave a sticky, bloody, hairy mess. Ask me how I know this...
02-12-2020, 07:35 PM | #73 |
This trap has a tube to put in the peanut butter which is almost impossible for the rat to eat without setting the trap.
02-12-2020, 08:52 PM | #74 | |
Sometimes you have to do a little bending of the trigger rod "thingie". Put two face to face, if they are eating one they step on the other. Also smear the peanut butter on the spring and other places. Cheap traps. Most sticky traps leave them alive and then you have to deal with that. But they do work. When I was living in Florida we would get fruit rats. Had a grapefruit, orange, and avocado trees. Think I would take out about a dozen a yr with rat snaps. Creepy rodents. Up here we have lots of nature around. Eagles (a week ago I was just watching 3 eagles eating a rabbit on the ice just outside my window), owls, minks, etc. So just not going to use poison personally. My neighbor likes those also 4dy. . Last edited by Tinker; 02-12-2020 at 09:16 PM. |
02-12-2020, 11:43 PM | #75 | |
No poison here! Five gallon bucket with just about six or seven inches of plain water in bucket. Dump the bucket and the carcasses the next morning. DD |
02-13-2020, 01:25 PM | #76 |
I found using a piece of thin wire to tie a piece of bacon to the trigger would get them every time.they tug on the bacon and die I also smear some bacon fat on the trap near trigger they get comfortable being near then get brave.works for rats as well
02-13-2020, 02:01 PM | #77 |
I have a toilet I built a frame work to set on top of instead of the bucket. All you have to do is flush to get rid of the critters!
02-13-2020, 05:00 PM | #78 | |
Does that turn them into "Sewer Rats" then //www.youtube.com/watch?v=xh0GHWww7Kc .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
02-13-2020, 05:49 PM | #79 | |
It absolutely can do that. The only water normally remaining in those pipes is the water in the bowl of your toilet. If you flush a live rodent, he's likely to want to continue living by climbing back up away from the water at lower levels, then fall right back into your toilet bowl. Don't let your wife read this post! In a related instance, I had a basement with a drainage pipe in the concrete piped directly to the storm sewer. Its cover screen became damaged, after which my basement was invaded by literally dozens of sewer rats. Trap the rats and cover the drainage pipe, no more rats.
Alan |
02-13-2020, 08:19 PM | #80 |
