07-07-2020, 09:00 PM | #1 |
Fuel Tank Sending Unit 1936
I found a NOS fuel tank sending unit FAA-9275-A that says its for 52-53 Ford passenger car 6-cylinder. I am trying to use it in my 36 but it doesn't read correctly. I thought that all the 6-volt units would be compatible with the 6-volt gauges?
Can anyone here shed some light on this subject. What will work and what will not. Any help would be appreciated. Thanks Dan |
07-07-2020, 10:46 PM | #2 |
Re: Fuel Tank Sending Unit 1936
How are you testing it?
07-07-2020, 11:53 PM | #3 |
If its that you installed it in the tank of your '36 and it gave you incorrect readings its probably due to the float arm not being the correct length - too long or too shory....
07-08-2020, 12:42 AM | #4 | |
I didn't install the sender, I tested outside the vehicle using jump wires for the lead and the ground at the tank, and yes it is positive ground. Then used the jump wires connected directly to the gauge. One jumper from the lead on the sender to the gauge and the other from the positive side of the battery to the mounting plate on the sender and got the same results, which tells me I don't have a issue with the wire going to the tank. When I hooked the sender up with the jumpers I put the float all the way up in the full position and the gauge was reading Empty. Then I turned on the ignition switch and the gauge would immediately move to full then would start to drop. Sometimes to 3/4 or 1/2 then would shoot back up to Full while still holding the arm in the Full position. If I tried to move the arm down to say 1/2 the gauge would drop to empty and if i moved the arm back up to the full position the gauge would not respond until I turned the ignition off, wait a minute then turn the ignition back on the gauge sometimes would not respond or would shoot to full. The best I can explain it is it acted erratic. I guess what my main question here is, should this sender be compatible with my gauge? Or is it possible my gauge is not working properly. To my understanding a gauge will either work or not and mine seems to be working? |
07-08-2020, 02:01 AM | #5 |
I suspect bad/poor connections with the "jumper" wiring giving you erratic readings. The sending unit you have should be compatible with the gauge in your '36....
07-08-2020, 10:25 AM | #6 | |
I'm wondering if the wire from the gauge to the sender on the vehicle may be bad or grounding as I did not disconnected it when jumping straight to the gauge? Any other suggestions or is it possible I just got a bad sender? |
07-08-2020, 10:42 AM | #7 | |
NOS does not necessarily mean a functional part. Sometimes it means it was returned because it was defective and somehow managed to get placed back in stock. I'd suggest by-passing the car's wire to the sending unit and making 100% certain that you have a good ground at the sender. That'll tell you if your NOS unit is operating properly.
07-08-2020, 10:39 AM | #8 |
You can check the gauge with a battery. Something like a "D" cell will work. Connect the D cell directly to the gauge with jumpers and see if it gives a steady reading.
07-08-2020, 12:03 PM | #9 |
Why would a six cylinder passenger car take a different sending unit than a V8?
Just because a gage or sending unit is 6 volt doesn’t mean it is comparable with every 6 volt gage or sending unit. I can only suggest what others have already posted, especially what Kube has said. Positive or negative ground also makes no difference. They work off from ohms. Keep us posted on what you find. I for one would like to know what the prblem is. |
07-08-2020, 02:30 PM | #10 | |
07-08-2020, 12:16 PM | #11 |
As a suggestion remove the dash gauge and jumper everything on the bench, if it works there, it is a problem with wiring, loose or dirty connections.
07-08-2020, 12:37 PM | #12 |
Ok, will try a couple more tests and will report back my findings.
A big thanks to all who replied. |
07-08-2020, 01:07 PM | #13 |
The six cylinder sending unit is likely different than the eight cylinder unit because the gas tank is a different size and shape which requires the wire arm to be a different length.
07-08-2020, 02:41 PM | #14 |
I thought that as well. Just couldn't imagine why Ford would install a different tank for the 6 vs. the 8.
07-09-2020, 10:59 AM | #15 |
It is most likely that the points in the new sending unit have corrosion on them. Connect an ohm meter between the center terminal and the case. Move the arm slowly and watch the meter. If you see wide fluctuations in the meter needle, the contact points are dirty or corroded.
Fix 1: move the arm along it full travel several times (50 minimum) and retry. If fix 1 did not work try fix 2 Fix2: pry the top cover from the sending unit and spray contact cleaner on the points. Be careful as the wires in there are smaller that a hair and easily broken.
TomO |
09-20-2021, 12:49 PM | #16 |
Does anyone have any info on a 1936 fuel gauge as to access and repair?
Thanks |
