Old 09-06-2020, 10:03 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Front Engine Support
I would like some experience feedback and pictures of the Float-O-Motor Front Engine Support installed in a Model "A." Can this support be installed without removing the radiator?
Bob Bidonde
Old 09-07-2020, 05:50 AM   #2
rally 1
Default Re: Front Engine Support
I use that front mount on both of my banger powered cars. The rear mount is oem.
‘30 Coupe, ‘31 Tudor
IMO, they work great.
Yes, they can be installed with the radiator installed, but might require a 90 degree drill for the drivers side.
I also use nyloc nuts instead of castellated, just my preference.
Ken
rally 1 is offline   Reply With Quote
Old 09-07-2020, 08:19 AM   #3
Bob Bidonde
Thanks Ken. I am going to install this mount in my 190A and 45B over the coming winter.
Bob Bidonde
Old 09-07-2020, 09:42 AM   #4
old31
Bob, I have the same one but I installed it when I had the engine out.
You will have to drill holes in the xmember for it to fit, that might be a real challenge with the radiator installed.
Old 09-07-2020, 10:00 AM   #5
Jack Shaft
They work great.I pulled the radiator and jacked up the engine a bit to get it in.
Jack Shaft is offline   Reply With Quote
Old 09-07-2020, 05:49 PM   #6
CarlG
CarlG's Avatar
Ken
I have often wondered if this front mount could be used with stock rear mounts.
Did it improve vibration any?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-08-2020, 10:31 AM   #7
katy
katy's Avatar
Is there any benefit to using the front FAMs compared to OEM?
Old 09-08-2020, 02:51 PM   #8
Big hammer
? Less moving parts? Drilling more holes in the cross member is a negative IMO
get a bigger hammer tap done
Old 09-08-2020, 07:38 PM   #9
Jack Shaft
Yes, IMO if you are using rear floatamotor mounts. It helps provide the support lost when the box style mounts were removed.
