Old 08-23-2020, 10:06 PM   #1
cw253748
cw253748's Avatar
Default New pitman arm too loose
Hello Ford Barn,
I just bought a new pitman arm from one of our good venders and it’s too loose on the gear box. I tightened the pinch bolt pretty tight and it still won’t tighten up. I will call the vender tomorrow but was wondering if anybody else has run into this? The old pitman arm tightens up very good when reinstalled.
Thanks
Chris
cw253748 is offline   Reply With Quote
Old 08-23-2020, 11:42 PM   #2
1930-Pickup
Default Re: New pitman arm too loose
Chris- That's an odd one.
I replaced my late-1930 pitman arm a few years ago with the shortened version to make steering easier. If anything, the arm was ever so slightly too tight. I had to spread the arm a little bit to slip it onto the gear box sector shaft.
Are you using the early 7-Tooth steering box, or a 2-Tooth? I'm not sure it will make a difference, but its good to know where you're coming from.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 08-23-2020, 11:55 PM   #3
quickchange
quickchange's Avatar
Stick in the vise & squeeze it up , then you can tighten the bolt easier , OR its faulty ,
quickchange is offline   Reply With Quote
Old 08-24-2020, 12:05 AM   #4
1930-Pickup
Yeah, that would do it, maybe.
I know that I'm way too anal-retentive. With my personality, I would find the root cause of a problem before squeezing the daylights out of it. But hey, that's why I don't have many followers
Old 08-24-2020, 07:16 AM   #5
cw253748
cw253748's Avatar
It’s a 2 tooth gearbox but that shouldn’t matter
Old 08-24-2020, 07:36 AM   #6
jak
There were some issues years ago, the 2 tooth sectors were a bit undersized. That may be your issue.
jak is offline   Reply With Quote
Old 08-24-2020, 08:28 AM   #7
Marshall V. Daut
Check your "Private Messages" in the top right corner of this webpage.
Marshall
Old 08-24-2020, 02:54 PM   #8
McMimmcs
McMimmcs's Avatar
instead of private messages share the information with everyone. If you don't it defeats the pu pose of the forum !
McMimmcs is offline   Reply With Quote
Old 08-24-2020, 03:18 PM   #9
Bill G
Bill G's Avatar
Marshall
I am having a similar issue with my new Pitman arm. Do you have info on that? I have tried the vise method, but I was afraid of cracking it because I was afraid it was cast, which I now see is not the case.
Bill G is offline   Reply With Quote
Old 08-24-2020, 03:22 PM   #10
1930-Pickup
I'm curious myself. Whats so 'private' about helping this member with a tech issue? The only thing that comes to mind is the age old motivator...money.
Old 08-24-2020, 03:28 PM   #11
1930-Pickup
Originally Posted by Bill G View Post
I am having a similar issue with my new Pitman arm. Do you have info on that? I have tried the vise method, but I am afraid of cracking it because it is cast.
I'm pretty sure they're forged. I was wrong once before though, maybe.
Old 08-24-2020, 06:23 PM   #12
Razkid
Marshall answered one of my questions using private message and no money was involved!
Razkid is offline   Reply With Quote
Old 08-24-2020, 07:09 PM   #13
Ruth
Marshall never shares his knowledge on the forum. But I guess that is his right to not participate in the discussion so everyone may learn. Like someone mentioned it kind of defeats the purpose of a "Forum".
forum | ˈfôrəm |
noun (plural forums)
1 a place, meeting, or medium where ideas and views on a particular issue can be exchanged.
Ruth
Old 08-24-2020, 07:34 PM   #14
The Master Cylinder
The Master Cylinder's Avatar
I guess he doesn't like us Model A guys. I have seen him post on the 'T' and V-8 forums and the Swap Meet.
Originally Posted by cw253748 View Post
I will call the vender tomorrow...
Thanks
Chris
Chris, Let us know what you find out from the vendor. It would be nice to know and perhaps help someone else with a similar problem.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-24-2020, 08:16 PM   #15
Jim/GA
Jim/GA's Avatar
This is a tough one.
I don't know about Marshall, but I have seen many people answer a question on this forum in the past and then get jumped all over by others about how they are wrong, they are ruining their car, etc. It makes a person not want to jump right up and answer, and be subjected to all that.
So maybe in the future people can post what they found as the SOLUTION to their problem, once it is fixed. I have seen a few of that sort of post here lately, which is good. Then others will have something to read that they know worked (at least for that person).
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 08-24-2020, 10:42 PM   #16
CarlG
CarlG's Avatar
It's probably because they don't want someone like you jumping all over their a** with theoretical information.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-25-2020, 07:07 AM   #17
aermotor
This is something that needs to be verified to see if it is forged. I read somewhere that the model A has over 150 forgings. If it is forged lay into it with the vice, it won't break.
John
aermotor is offline   Reply With Quote
Old 08-25-2020, 10:09 AM   #18
katy
katy's Avatar
Not likely that the arm would be made out of cast iron, that would be a major safety issue.
Old 08-25-2020, 10:46 PM   #19
cw253748
cw253748's Avatar
Called the vender who could check the blue prints and give me the actual spec. Of the pitman arm and the new arm was inspect. I had to crank the pinch bolt a bit tighter and the pitman arm is now nice and tight to the shaft.
Old 08-26-2020, 07:07 AM   #20
aermotor
So, did the vender say it was forged? If so that would give peace of mind that really torqueing the bolt won't hurt the arm.
John
