Old 08-09-2019, 05:19 PM   #1
pgerhardt
pgerhardt's Avatar
Default Model A horn question
What size is the screw that holds the horn cover on the model A horn (mine is a Stewart Warner)?
It looked like a 10-32, but it is not. The thread count is 32, the size is however, slightly smaller. What do I care? Because removing the horn cover for cleaning and lubrication is something that is needed once in a while, but getting the horn cover screw started is a PIA while the horn is on the car. So I bought these really nice nylon (no chance of shorting out the brush which rides under this screw) one inch (the original screw is 3/4") 10-32 screw. I thought I would put a slight taper on the end of this screw so finding and starting the screw in the threaded hole in the horn frame would be a snap!
Of course that won't work since the hole in the horn frame is slightly too small!
I could (and probably will) run a 10-32 tap through the hole and make it the right size for my screw, but I would rather keep the horn all original and find the correct size screw. Could it be metric?
pgerhardt is offline   Reply With Quote
Old 08-09-2019, 07:16 PM   #2
davehc
davehc's Avatar
Default Re: Model A horn question
https://www.brattons.com/horn-cover-screw.html
davehc is offline   Reply With Quote
Old 08-09-2019, 08:29 PM   #3
Jon-Ohio
8-32 x 13/16" according to Brattons catalog
Jon-Ohio is offline   Reply With Quote
Old 08-09-2019, 09:53 PM   #4
pgerhardt
pgerhardt's Avatar
Found them. THANKS!!
File Type: jpg Screen Shot 2019-08-09 at 10.52.11 PM.jpg (21.0 KB, 29 views)
