Old 10-07-2020, 09:48 AM   #1
rembrandt78737
Default 1929 Model A Briggs Fordor Steering bracket fix
Anyone out there figure out how to use a later steering column support on a 1929 Briggs Fordor? I had to fix a tank leak due to the tank mounted steering column support and don't want to use the tank mount again. I see a fair number of posts for other body styles, but the Briggs has a different dash support. In the 29 Briggs Fordor, the tank/dash mounts under a cowling. The upper flange of the tank is unsupported by the dash support except in the middle. It also sits almost flush beside the dash support. You cannot access the top of the tank flange or the top of the dash support flange to install nuts, so even if I drilled holes in the horizontal portion of the support, all the connections would be blind. Attempting to mount the bracket further forward using a custom bracket anchored to the accessible part of the dash support does not offer sufficient clearance with the steering column. I see no way to adapt the 30 support to this car. I'm open to custom options, just curious if anyone has come up with one.
rembrandt78737 is offline   Reply With Quote
Old 10-07-2020, 02:16 PM   #2
PalAl
PalAl's Avatar
Default Re: 1929 Model A Briggs Fordor Steering bracket fix
I'm going to jump on the train and follow this one, I had all the parts and ran into the same problem. Someone out there has figured this out I bet.
File Type: jpg 29 Silver Creek Rail Line Orphanage.jpg (148.8 KB, 99 views)
PalAl is offline   Reply With Quote
Old 11-29-2021, 05:20 PM   #3
rembrandt78737
Meant to post this awhile back. Unable to find an existing Model A bracket that would work with the 29 Fordor, I was forced to wing it. Built a simple bracket that bolted to the frame and connected an after-market "hot-rod" steering column bracket. It's kind of ugly, but it works and isn't as noticeable as I thought it would be. I'm sure the purists would frown on it, but I did what I had to do. I'll make a fancy leather skirt for the bracket to hide it's utilitarian ugliness, but it works.
Old 11-29-2021, 07:31 PM   #4
Dennisfly
Dennisfly's Avatar
Been there done that. It's all right here:
https://www.fordbarn.com/forum/showthread.php?t=278394
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 11-29-2021, 07:38 PM   #5
mercman from oz
mercman from oz's Avatar
Neat 1930 Ford Model A Sedan owned by PalAl
Old 11-29-2021, 10:13 PM   #6
Bob C
Here's a link to a Tom Endy article. http://www.santaanitaas.org/wp-conte...lumn-Mount.pdf
Old 11-30-2021, 12:42 AM   #7
PalAl
PalAl's Avatar
Thank you....... it's a 29 Briggs Standard 165-B
