Old 08-02-2020, 07:16 PM   #1
Detonator
Detonator's Avatar
Default '35 tie rod clamps; tacked on??
In disassembling my front end, I discovered that the clamps on both ends of the tie rod had a tiny tack weld holding them to the rod. Is this stock? There were a lot of little things done to this car during a so-called "restoration" decades ago, so I'm never quite sure what's Henry. Thanks.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 08-02-2020, 08:25 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: '35 tie rod clamps; tacked on??
I'm pretty sure stock 35 had an adjustment of the tie rod on one end only, the other end was integral with the tie rod. Don Rogers, post a picture for us. (Mine sure isn't stock in this regard.) Lawson
Old 08-02-2020, 09:06 PM   #3
19Fordy
19Fordy's Avatar
NOT a stock OEM assembly technique.
Old 08-02-2020, 09:42 PM   #4
Don Rogers
Don Rogers's Avatar
Detonator, I believe that at least one tie rod supplier to Ford in 1935 tacked the end clamps to the rod. I also believed that they were tacked in only one place on each clamp. Here's a drawing showing the practice on a 36 drag link end.
Don Rogers is offline   Reply With Quote
Old 08-02-2020, 10:42 PM   #5
petehoovie
petehoovie's Avatar
Old 08-02-2020, 10:46 PM   #6
cas3
i've seen some welded too. it looks better than a hillbilly weld, but never knew for sure if ford did it
Old 08-02-2020, 11:52 PM   #7
Detonator
Detonator's Avatar
Thanks...mine were tacked at both clamps, and no, it wasn't a hillbilly/bird crap/bubblegum weld. If it was an arc weld, it was pretty small and clean.
Seabright Hot Rods
Old 08-03-2020, 08:24 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Some of the tie rod clamps on my original '35's are tack welded to the rod.
John
Old 08-03-2020, 08:33 AM   #9
19Fordy
19Fordy's Avatar
Opps! I will now "sit on a tack" corrected.
