05-24-2019, 08:33 PM | #1 |
compressor water and moisture extractor
It's getting humid out this time of year. My compressor is spitting out water. I cannot imagine doing any painting with this situation. I have no need to oil air tools, as I have electric impact wrenches. Does anyone have a recommendation for a water and moisture extractor for my compressor? I don't mind spending a couple of hundred, but some of them out there are over the top in cost.
05-24-2019, 09:29 PM | #2 |
Re: compressor water and moisture extractor
Anything made by DeVilbiss is great. Don't shoot cheap because the quality just isn't there. I have a DeVilbiss water and air separator and so far I haven't had any complaints.
"The more things change, the more they stay the same." |
05-24-2019, 10:38 PM | #3 |
Have you opened the drain valve on the bottom of the tank and drained the water out?
Dave / Lincoln Nebraska |
05-24-2019, 11:13 PM | #4 |
How far is the compresser from the point of use,how large is the pipe, are there water drains, slope in pipes--- this gives the moisture a chance to drain back
05-25-2019, 06:09 AM | #5 |
05-25-2019, 07:06 AM | #6 |
https://www.ebay.com/p/AC-110v-1-2-2...d=173801145062 |
05-25-2019, 08:36 AM | #7 |
Use black pipe not copper or plastic to condense the moisture and mount your separator as far down stream as possible.
05-25-2019, 09:35 AM | #8 |
I use one of these, mounted vertically: https://www.princessauto.com/en/deta...er/A-p8055757e
05-25-2019, 06:11 PM | #9 |
I have 2 cheapy inline filter/moisture separators upstream of the pressure regulator. Also an air conditioner and a dehumidifier in the workshop. Very little moisture in the air being compressed. It works very well, cool and comfortable.
05-26-2019, 07:33 AM | #10 |
I made a condenser from a commercial air condition coil.
I “banked” it to accommodate the CFMs by basically dividing in half. I have a large separator coming off it Used it for 30 years and no shop condensation what so ever Can post pics if anyone has that much interest |
05-26-2019, 08:52 AM | #11 |
Get on the internet and investigate removing moisture from air going to a paint booth. You will find hints and air line schematics. I had a similar problem. One of the simple things to do is get 50 feet of 1/2 in. min. coiled air line to cool the air coming out of the compressor. Then route the air line to a filter-separator. When spraying, I have a small air bleed at the bottom of the tank and at the bottom of the filter to drain any moisture. Try not to have heavy draws of air while spraying. Take your time. Good luck, Ed
