Old 12-17-2020, 01:30 AM   #1
35ragtop
35ragtop's Avatar
Default So whats it for?
Hi guys,
I took this fitting out of the exhaust system (LHS below the manifold) on my 48 Mercury. I would like to know its correct purpose please. To me it would seem that it is for some cold weather purpose but in our climate it would be of no benefit. The car is ex California in recent times.
I look forward to your opinions. I couldnt find any reference to it in my parts book.
thanks
Dave
35ragtop is offline   Reply With Quote
Old 12-17-2020, 01:35 AM   #2
Alaska Jim
Alaska Jim's Avatar
Default Re: So whats it for?
That is a heat riser. its function is to cause enough back pressure to force more of the exh. gas through the intake manifold crossover to help heat the fuel during cold weather to help atomize the fuel, so that it ignites easier for cold weather drivability. yours is missing the spring that opens the valve as it heats up and reduces the back pressure. when it is cold, before the engine is run, the valve is normally closed. hope that this explanation makes sense to you.
Alaska Jim is offline   Reply With Quote
Old 12-17-2020, 04:54 AM   #3
McMimmcs
McMimmcs's Avatar
i think they called them a heat riser valve,
McMimmcs is offline   Reply With Quote
Old 12-17-2020, 10:09 AM   #4
54vicky
54vicky's Avatar
to add to what is written it is missing the spring that fits on the outer portion.they are (were) handy if you live in a humid climate as they helped with warm up and kept (keep) the moisture from freezing in the throat of carb while engine warms up.later years used a pipe from the manifold to do a similar thing.common until F.I. came along
54vicky is offline   Reply With Quote
Old 12-17-2020, 10:37 AM   #5
34PKUP
34PKUP's Avatar
Obviously in your state of exuberance, you failed to read post #2 above
34PKUP is offline   Reply With Quote
Old 12-17-2020, 10:53 AM   #6
McMimmcs
McMimmcs's Avatar
Not a big deal, better to be told twice than not at all !
Old 12-17-2020, 01:49 PM   #7
51woodie
51woodie's Avatar
Check on eBay. There are a few listed. Mac's also lists one for a Tbird. Just need to confirm c/c on the bolt holes, and size of the bore.
https://www.ebay.com/itm/NOS-FoMoCo-...-/380967885863
https://www.macsautoparts.com/1955-1...6-28306-1.html
51woodie is offline   Reply With Quote
Old 12-17-2020, 03:23 PM   #8
35ragtop
35ragtop's Avatar
Thanks fellas,
I knew that the answer would be here on this site.
I definitely dont need to warm anything up in our climate. It will make a nice conversation piece on the bar top.
Merry Christmas
Dave
Old 12-17-2020, 04:10 PM   #9
Lawrie
Lawrie's Avatar
Dave you might want to modify that to help the dist stay warm and run in deep water.LOL
Lawrie
Lawrie is offline   Reply With Quote
