Old 09-17-2021, 12:24 PM   #1
Vern
Vern's Avatar
Default Trick for removing oil pan singlehanded
As part of putting a new Burtz block in my roadster, I had to remove the oil pan from the old block. After draining the oil, I knew there was still oil in the drip pan and that the pump would drop along with the pan. Not wanting to drip more old oil onto the floor, I came up with a method of lowering the pan slowly and evenly. Taking a scissors jack, I put a thin wood board across the top, tied in place with zip-ties. I was able to get the pan low enough to slip the jack out, grab the pan and not make a big mess. Even so, I had a large pan filled with cat litter under the jack just to make sure.
Vern is offline   Reply With Quote
