07-23-2015, 02:22 PM | #21 |
Re: 600 W Tranny Oil at Walmart
Lube oils from crude oil distillation are a mix of straight and branched chain HC's. The STP MSDS lists simply "Mineral oil" (AKA a crude oil, paraffinic, alkane) mix as the base ingredient. That's the same (approximately 64% straight chain) crude base source used for lubricants.
07-23-2015, 04:33 PM | #22 |
Bruce,
Did you see what your started? Rog |
07-23-2015, 04:42 PM | #23 | |
Oh course now lube crudes are getting scarce and non-lube crude gas oils are hydrocracked to make lubes out of them. It is a viscosity modifier to make thin lube oil into thicker lube oil. Last edited by mrtexas; 07-23-2015 at 04:55 PM. |
07-23-2015, 04:47 PM | #24 |
I think for Meropa 680 it was $52 for 5 gallons. Likely it has gone up since 2006, but I would not think it has gone up to $35 per gallon. If you paid that price someone fleeced you good. Rod
07-23-2015, 05:38 PM | #25 |
According to STP their additive is designed to be mixed with oil not run straight.
07-23-2015, 06:38 PM | #26 |
07-23-2015, 06:47 PM | #27 | |
Bob |
07-23-2015, 07:23 PM | #28 |
That 680 stuff gets very stiff in cold weather. Good for summer driving. Here is 600W the 460 stuff: http://www.mobil.com/Egypt-English/L...inder_Oil.aspx
http://www.amazon.com/MOBIL-600W-SUP.../dp/B00G97EIJ2 I've tried both. 680 great for a hot summer makes shifting a breeze. In cold weather it takes two hands and a lot of muscle to shift. |
07-23-2015, 10:00 PM | #29 |
BUT, duz anyone READ?? Does anyone even read whut's in the FOOD, thet you HOG down EVERYDAY? Does everyone know that when you drink JOY JUICE, the ALCOHOL is singled out & goes DIRECT to yo' LIVER & "COOKS" thet Dude & some goes to yo' "BRAIN" & cooks a mess uf BRAIN CELLS & you feel TIPSY & you wonder why you feel like CRAP, in the A.M.
YES, this is Model A related, DON'T DRINK & DRIVE WITH A SICK LIVER & A SUB-STANDARD BRAIN! Bill W.
07-23-2015, 10:10 PM | #30 |
Merpo 680 is now $88.81 for 5 gallons. Some of the local Model A people mix in 20% Lucas oil stabilizer. Rod
07-23-2015, 10:39 PM | #31 |
Even OLIVE OIL feels SHLICKERY, don't put some unknown, strange stuff in your car, just because someone said so!!! I once checked out with 4 grocery items & a quart of PENNZOIL, check out artist, Richard, inquired, "And what are we cookin' tonight"?
Bill W.
07-23-2015, 11:09 PM | #32 | |
07-26-2015, 10:11 AM | #33 |
Thanks to the knowledge in this forum; I have drained my transmission and put 600 wt oil from a local Model A supplier, and then added about a pint of STP.
This does seam to work much better than the straight STP. By the way, 24 hours to drain the STP, and looking inside, with the shifter cover removed, there was a sticky coating on everything. Thank You again for the knowledge.
Brian French; 1930 Briggs Town Sedan |
