05-22-2022, 04:04 AM | #1 |
Filling holes in firewall.
Can holes in firewall be safely filled without removing the gas tank?
TIA Dick |
05-22-2022, 06:05 AM | #2 |
Re: Filling holes in firewall.
Empty it, fill with water to the top. The drain and blow dry with just air when complete.
Remember vapors are as bad/word than liquid to explode. |
05-22-2022, 06:10 AM | #3 |
Drain after holes filled?
Thanks Dick |
05-22-2022, 07:02 AM | #4 |
Yes when welding, sparks and heat completed
Just remember that half full could still have vapors…..so full! Also the carb and lines have gas It is not foolproof so travel carefully at own risk |
05-22-2022, 09:31 AM | #5 |
Engine in hospital no worries there
Thanks Dick |
05-22-2022, 09:44 AM | #6 |
05-23-2022, 12:09 PM | #7 |
The 1928 &'29 firewalls have a horizontal bolted joint. Above the joint there is only about 2" clearance to the gas tank wall. Below the joint, the firewall has nothing behind it to worry about.
Bob Bidonde |
05-23-2022, 03:37 PM | #8 |
Nothing but a fuel valve, fuel line, and a sediment bowl attachment just above the heater carry through inside the cab if so equipped. The sediment bowl, carb feed line, and carburetor are on the engine side in that right side area. It just depends on where the unwanted holes are. If the holes are on the left side then there is less chance of problems. Welding stuff up throws a lot of sparks and they go everywhere if using MIG. I gas weld myself but that little torch puts out a pretty good sized flame. I wouldn't want all that fuel system stuff even close to where I'd be welding. After the welding then the grinding begins and that will throw sparks everywhere.
A lot of these old cars have had aftermarket heater set ups installed and some of them end up with a lot of extra holes they don't need. |
Thread Tools | |
Display Modes | |
