06-02-2021, 03:47 PM | #1 |
Red-Lite Misery
After I've done a nice run outside of town, I'm getting hesitation/stalling while waiting for lite-change, they're getting longer now. Would the Model B Zenith be worth it? This is my second Model A Zenith now, and was wondering if I should consider.
Thanks |
06-02-2021, 04:34 PM | #2 |
Re: Red-Lite Misery
Fix what you have. If it is the carburetor, it should be an easy fix. Its a simple carburetor. Clean it, a tag wire thru the passages followed with a can of Deep Creep spray and some air should work. Set the float level. Adjust the idle mixture and speed, set the GAV at 1/4-3/4 turn out and it should be good to go.
First make sure there is not an air leak and the ignition system is good. |
06-02-2021, 05:22 PM | #3 |
Re: Red-Lite Misery
06-02-2021, 06:44 PM | #4 |
Re: Red-Lite Misery
I had that problem. Sediment in the float bowl was causing it.
06-02-2021, 10:13 PM | #5 |
Re: Red-Lite Misery
What’s the ambient temperature? It sounds the the beginnings of vapor lock. Try insulating the gas line and adding some marvel mystery oil to the gas. I ended up with an isolation spacer between the carb and manifold. I also built an aluminum deflector that not only shields the carb from the engine, but directs air from the fan. My car doesn’t “hesitate” after a run at the traffic lite anymore. If you shoot your carb in different places with a temp gun, you’ll be surprised how hot the carb gets.
06-03-2021, 04:12 AM | #6 | |
Re: Red-Lite Misery
Sent from my iPhone using Tapatalk |
06-03-2021, 01:11 PM | #7 |
Re: Red-Lite Misery
Also, check for a short in the stoplight switch
06-04-2021, 07:42 AM | #8 |
Re: Red-Lite Misery
Gas cap vent? Chap
06-04-2021, 08:07 AM | #9 |
Re: Red-Lite Misery
why I put a magnet in all of my float bowls. |
06-05-2021, 12:18 PM | #10 |
Re: Red-Lite Misery
I’m not sure the pic is going to come thru
06-05-2021, 05:37 PM | #11 |
Re: Red-Lite Misery
Xxxxxxxxxx
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 06-06-2021 at 08:38 AM. |
06-05-2021, 07:30 PM | #12 |
Re: Red-Lite Misery
06-06-2021, 08:44 AM | #13 |
Re: Red-Lite Misery
06-06-2021, 10:21 AM | #14 |
Re: Red-Lite Misery
So after a nice long drive everything is warmed up and adjusted for cruising. I would try opening the GAV and maybe retarding the timing a little. Can you get it to die parked in your driveway? after its warmed up? I would adjust your carburetor idle speed and idle air
06-06-2021, 07:05 PM | #15 |
Re: Red-Lite Misery
06-06-2021, 07:22 PM | #16 |
Re: Red-Lite Misery
That shield looks interesting. Do what ya gotta do to keep driving is what I always say. So, good for you!
