Old 08-10-2019, 03:17 PM   #1
FrankWest
FrankWest's Avatar
Default needed 6 volt battery charger
Harbor Freight once sold a 6 volt battery charge that worked great charging optima 6 volt batteries. My 6 volt charge no longer works....Not so great.
Who sells a decent charger?
FrankWest is offline   Reply With Quote
Old 08-10-2019, 03:26 PM   #2
petehoovie
petehoovie's Avatar
Default Re: needed 6 volt battery charger
HOME DEPOT > https://www.homedepot.com/p/BLACK-DE...BM3B/202710992
BLACK+DECKER Model # BM3B $23.05
1.5 Amp Battery Charger/Maintainer compatible with 6- and 12-Volt AGM, GEL and WET automotive/marine batteries
  • For use with both 6-volt and 12-volt batteries
  • Automatic microprocessor battery monitoring
  • Reverse connection warning and ready indicator
$15.18 at AMAZON > https://www.amazon.com/BLACK-DECKER-.../dp/B0051D3MP6
Product description The BLACK+DECKER BM3B high frequency battery charger and maintainer is used to keep batteries in stored vehicles and battery applications at optimal capacity during the off season. Charges 6 volt and 12 volt AGM, GEL and WET batteries in RVs, specialty vehicles, antique and classic cars, marine deep cycle batteries, motorcycles, lawn mowers, ATVs, snowmobiles, and personal watercrafts. Slide the voltage selector switch to either 6V or 12V depending upon the battery you are charging. Connect the battery charger and maintainer with the included battery clips or battery ring terminals. Charging automatically stops when battery is fully charged or topped off and switches to float mode monitoring to maintain charge. Built-in circuit protection guards against overcharging, reverse polarity, or short circuit and is ETL certified for performance and safety. The BLACK+DECKER BM3B battery charger and maintainer has a built-in mounting bracket for convenient placement and includes a limited 1 year manufacturer warranty.
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 08-10-2019, 05:27 PM   #3
FireEngineMike
FireEngineMike's Avatar
Check out the chargers at "no.co". Four letters with a dot in the middle. Also available on amazon. I have two for maintainers, but also charge with them.
FireEngineMike is offline   Reply With Quote
Old 08-10-2019, 05:38 PM   #4
philipswanson
No Co seems expensive. Check out Battery Tenders on E Bay.
philipswanson is offline   Reply With Quote
Old 08-10-2019, 07:42 PM   #5
39portlander
39portlander's Avatar
Frank, I bought this one several years ago it does 6 and 12V. Battery extender SC4 model BE01250.
Has a rate selector 3A maintainer or 15A rapid charge, battery type standard, AGM or gel. If your not paying attention it even has a revered clamp indicator. I think I bought it @ O'Reilly auto.
39portlander is offline   Reply With Quote
Old 08-11-2019, 07:06 AM   #6
chap52
chap52's Avatar
I use, and recommend that slow charger that Petehoovie posted. I have connected the battery hook up directly to the battery posts and run the pigtail under the floor mat. Can't tell it's there and if I decide to top off the battery charge I just plug it in. A handy set-up... Chap
chap52 is offline   Reply With Quote
Old 08-11-2019, 11:57 AM   #7
slowforty
slowforty's Avatar
Wal-Mart has a good charger. 6 and 12 volt with a battery maintainer and will charge Optimo batteries, Was originally a Shumacher brand but now has a Wal-mart label.
slowforty is offline   Reply With Quote
Old 08-11-2019, 11:12 PM   #8
Tinker
Tinker's Avatar
Get a Schumacher charger for basic all around charging. They are cheap. Good charger. If lucky they can be found at a garage sale or auction.
optima's need to be charged not tendered other then running (gen). Charge them twice a yr, 10-14 yrs, 2 batteries. Great battery.
A optima rep has been on there and has said treat it like a battery. It does not not to be tended.
Old 08-12-2019, 01:29 AM   #9
Graeme / New Zealand
Graeme / New Zealand's Avatar
Save a battery charger maintainer. Really good unit. not only charges but maintains. Also this unit can bring batteries back from the dead by cleaning the plates. Can be got in 6v 12 v and 24. I've got a 6 and also a 12v and use them all the time
US unit too
https://www.youtube.com/watch?v=E1MCYd0Ket0
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 08-12-2019, 02:46 PM   #10
supereal
supereal's Avatar
We use the "Battery Tender" that is adjustable for 6 or 12 volts as a maintenance charger. They are readily available. We use them for both conventional lead-acid batters, and for the Optima, as well.
supereal is offline   Reply With Quote
Old 08-12-2019, 03:12 PM   #11
1948F-1Pickup
1948F-1Pickup's Avatar
I worked for a battery manufacturer a few years back. Midtronics for battery
analyzers. Schumacher for regular chargers.
I have both Noco Genius and Battery Tender Jr for maintainers. I'm doing a
"trial" on those two to see which one is better on Optimas right now.
1948F-1Pickup is offline   Reply With Quote
Old 08-13-2019, 07:18 PM   #12
barnfind
HF has a small unit that does 6 and 12 and AGM, GEL, and STD.
It was less than 25 with a coupon.
Works great.
barnfind is offline   Reply With Quote
Old 08-14-2019, 11:34 AM   #13
jim1932
jim1932's Avatar
search on 6/12 volt on google, they are out there. Try Tractor Supply. I have a 6volt battery tender and a 6/12 craftsman that I bought when sears was still going.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 08-14-2019, 07:45 PM   #14
Tinker
Tinker's Avatar
https://www.fordbarn.com/forum/showt...08#post1766908
post 13 on the thread. I'm sure if you have questions they can be asked directly by pm, concerning the optima battery. Great battery in my thinking.
