10-08-2016, 09:31 AM | #1 |
Pulling rear main cap with counter weighted crank
Has anyone had any luck being able to pull a rear main cap with a counter weighted crank, in the car? I've heard it's possible, and I've heard it can't be done. I'm resealing a rear cap on an inserted motor, and if I don't have to pull the motor, that would be fantastic.
Cowtown A's |
10-08-2016, 11:00 AM | #2 |
Re: Pulling rear main cap with counter weighted crank
Logan, unfortunately the flywheel housing is in the way as you have likely figured out. This was the major reason why Ford made the design change for the Model-B flywheel housing. I had one car several years ago come thru where the flywheel housing was cut in the inspection plate area. I feel certain I have a picture of it but I cannot seem to find it at the moment. As I recall, it wasn't cut much and a piece of sheetmetal was added to the inspection plate to cover the larger hole.
10-08-2016, 11:02 AM | #3 |
I have seen a lot of different sizes of counterweights--you will probably have to try and see---
10-08-2016, 12:14 PM | #4 |
Additional note: This info might not help as it involves a B engine ...
When I built the full pressure B block in 1976 I cut a "V" notch in the Model A Flywheel housing per instructions from Bill Kenz. This engine had a factory "C" crank and the bearing cap was removable IF the crank was turned to a certain position. I never tried it with a "BB" crank with the pinned on counter weights. Like stated above there are so many counter weight sized weights that you would have to try it and see how big the V Notch has to be and if it is removable with your crank. As I remember one of the problems was that the B rear main bolts, being longer, would not go up far enough to get the cap out in addition to the larger size of the cap itself and getting the cap removed. Last edited by Benson; 10-08-2016 at 12:49 PM. |
10-08-2016, 10:44 PM | #5 | |
10-09-2016, 08:17 AM | #6 |
did I miss something here. if you are talking an A engine with a counter weighted crank yes you can remove the rear main cap. if you are talking a B engine than you go to what Brent had to say. |
10-09-2016, 10:33 AM | #7 |
the rear main cap can be removed on a counter weighted crank as I have done it, it is a very close fit and you will have to fiddle around finding the right position, however different counter weights from mine may make it impossible.
10-09-2016, 12:52 PM | #8 |
No, this isn't one of his motors. The crank was originally weighted and balanced by john in Albuquerque, NM. The only ,real problem I see with trying to get it in and out in the space allotted, besides the fact that it may not come out, is the thrust washers slipping out of place or falling into the bell housing when moving it around.
Cowtown A's |
