04-05-2014, 02:09 PM | #1 |
40 Ford oil drain plug conversion
Is there a way to adapt a smaller drain plug on the original large one to slow the oil from gushing out when changing. Seems like I saw a how to item a while back on the barn. Anyone have a copy of this.
Thanks Warren |
04-05-2014, 02:36 PM | #2 |
Re: 40 Ford oil drain plug conversion
Having the oil gush out is good, it will carry more debris out of the pan
04-05-2014, 04:25 PM | #3 |
Remove your stock drain plug and weld or braze in a threaded steel bung like this.
http://www.summitracing.com/parts/ar...8203/overview/ Than you can use which ever drain you choose. |
04-05-2014, 05:18 PM | #4 |
just drill a small hole in your drain plug and tap it for a small plug, you can choose what size plug you want to tap to
04-05-2014, 11:11 PM | #5 |
Thanks for your replies. This was what I had in mind.
Warren |
04-06-2014, 10:16 AM | #6 |
http://www.macsautoparts.com/ford_me...+plug&x=17&y=8 |
04-06-2014, 10:45 AM | #7 |
04-06-2014, 01:45 PM | #8 |
That's really neat. Beware of speed bumps.
04-06-2014, 04:31 PM | #9 |
What 1940 said.
04-06-2014, 06:34 PM | #10 |
Engines without PCV tend to generate sludge, especially if run with low temp or no thermostats and are too cool a lot of the time...as Kurt said, the rush to the exit is good at moving out the crud. You can also help some more out with a finger with the big drain plug.
