Old 02-04-2012, 03:19 PM   #1
Kurt in NJ
Kurt in NJ's Avatar
Default Best stud puller
I have used many different types of stud pullers, these Van Normen ones have worked the best, don't slip, release easy ---sometimes they show up on E-bay reasonable --this set I just got for 10$, they wear well, my first one has removed many more than 500 studs during my use and still shows no wear ---that doesn't count how many before my use, they work the same in both directions, and they come apart easy to clean the teeth --they grip so good that you can twist off any stud without slipping ---yet they give good feel that you will twist off fewer studs (solid grip instead of a springy grip).
Old 02-04-2012, 05:56 PM   #2
JTW
JTW's Avatar
Default Re: Best stud puller
After everyone reads your thread and sees the pictures I'll bet there will be more competition for the next one that shows up. That looks like a great tool, thanks for the tip.
Driving old Fords since 1947
JTW is offline   Reply With Quote
Old 02-04-2012, 08:03 PM   #3
James Rogers
James Rogers's Avatar
I have 2 sets like that, one with 3 sizes and a single and have to agree with you on their use. I bid on that set but with what I have I didn't get too interested. Glad you got them.
James Rogers is offline   Reply With Quote
Old 02-04-2012, 09:01 PM   #4
miss victoria
Snap on sells a good one $$$ but it will snap a stud before it slips.
miss victoria is offline   Reply With Quote
Old 02-05-2012, 11:49 AM   #5
ABento
Snap on has sized pullers, so you need one for each size you pull, they do have a kit of several up to 1/2 or 9/16 they work real well and don't scar the threads, but they are pricey.
ABento is offline   Reply With Quote
Old 02-05-2012, 07:24 PM   #6
Jamie86
Snap On CG-500 set 1/4" thru 5/8" this is a great set to have. They do cost a pretty penny, unless you can find them used. The MAC wedge stud remover works well,too.
Jamie86 is offline   Reply With Quote
Old 02-06-2012, 07:50 PM   #7
Bruce Lancaster
Snap-on collett type are the best. By S-o standards, they aren't even pricey, especially when compared to a long thrash with a broken stud.
I hope this link works:
http://buy1.snapon.com/catalog/item....re&dir=catalog
You can save a small amount of money by getting just Ford size collett and the puller housing from the spare parts section.
FWIW, Ford shows and lists by Ford number a collett type puller in the V8 overhaul manual. Those flatheads used the same stud sizes (except length) as Model A's...
