Old 07-10-2022, 05:29 PM   #1
Pcb50
Default Spider wheel cover removal
Hi everyone. Long time lurker but first question. My new to me '39 conv sedan has full wheel covers that I'm having trouble removing. Can't see a way off without damage. I'm replacing tires with DBs so the question. Thank you. Paul.
Pcb50 is offline   Reply With Quote
Old 07-10-2022, 05:33 PM   #2
38 coupe
38 coupe's Avatar
Default Re: Spider wheel cover removal
There is a raised lip at the point where the standard hubcaps stop. You put the hubcap removal tool under that lip. Do NOT pry on the "spokes" outside that lip.
Old 07-10-2022, 05:40 PM   #3
Kube
Kube's Avatar
I use a wooden dowel from the inside. Catch the lip and tap. Have a friend there to catch the cap.
Old 07-10-2022, 05:44 PM   #4
KiWinUS
KiWinUS's Avatar
Kube nailed it.
Old 07-10-2022, 06:07 PM   #5
Pcb50
The tire tool worked perfectly! Thank you both for replying. Later I will compose a proper introduction for myself and the car as I would like to see if it's a "known" car. Thanks again.
Old 07-10-2022, 07:59 PM   #6
ford38v8
ford38v8's Avatar
Here's the tool I made. A simple slide hammer pulls the hub cap from the front rather than pushing from behind. No helper needed. Hook it, tap-tap and done.
Alan
Old 07-10-2022, 09:52 PM   #7
swoopNZ
MEMBER EMERITUS
Strange that Ford carried over the 38 deluxe design for 1939 for the spider accessory hubcaps instead of using the new 39 deluxe pattern.
swoopNZ is offline   Reply With Quote
Old 07-10-2022, 11:32 PM   #8
ford38v8
ford38v8's Avatar
I would take a wild guess that as the economy was lagging, an overstock of ‘38 accessory spiders factored into that decision.
Alan
Old 07-12-2022, 05:43 AM   #9
glennpm
glennpm's Avatar
Nice job making the tool Alan!
Old 07-12-2022, 09:29 PM   #10
BrianCT
BrianCT's Avatar
When I had my 36 I found that a paint cad lid remover worked and was kept in the glove box.
[FONT=Comic Sans MS]
BrianCT is offline   Reply With Quote
