Old 04-10-2020, 09:30 AM   #1
JKY
Default Starter Switch Question
I have an A I'm looking as a potential purchase, 29 Fordor. When we went to see it the owner tells me the starter just spins when the battery is connected. We look at the starter switch and it appears to be stuck in the start position. Checking his parts stash we find a new switch. We put it on to get it going but the starter rod is stuck and won't depress. I assume it's out of alignment and that's what caused the old switch to fail, he pushed it in and it wouldn't retract so the starter just kept spinning.
The fellow is not to mechanically sauve and insists that he needs to take the starter in to be repaired.
Is there any adjustment to the starter rod I can make to get it to free up?
Thanks!
JKY is offline   Reply With Quote
Old 04-10-2020, 09:35 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Starter Switch Question
Just u screw it and reattach the rod to the new one. You may want to pull it to verify that the be did is working properly.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-10-2020, 09:36 AM   #3
JKY
Mike
Thanks, we did that. Once installed the rod is stuck and won't slide up or down.
Old 04-10-2020, 09:43 AM   #4
Will N
Will N's Avatar
The rod passes through a grommet in the firewall. Could be the rod is binding in the grommet. Disconnect the rod from the switch, and see if the rod moves freely. If not squirt some oil on the grommet and work it back and forth until it moves freely.
Will N is offline   Reply With Quote
Old 04-10-2020, 09:45 AM   #5
Gary WA
Gary WA's Avatar
Remove starter check Bendix. Low battery. One of my cars did the same thing yesterday, Battery showed 6volts but as soon as hit starter not enough! Battery was 5 years old. New battery running Great.
www.whidbeymodelaclub.com
Old 04-10-2020, 09:56 AM   #6
JKY
Thanks all. I'll give these a try.
Old 04-10-2020, 10:44 AM   #7
katy
katy's Avatar
Alternately, tie a string under the head of the starter push rod, after pushing the rod to engage the starter and start the engine, pull the string to disengage the starter.
Old 04-10-2020, 11:41 AM   #8
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
It could be that the engine has shifted and put the rod into a bind. This happens often with the choke rod. See if the choke rod is free to slide. There is nothing to the starter switch. Take it apart and see what is wrong. I'm pretty sure it's not the starter motor.
Jacksonlll is offline   Reply With Quote
Old 04-10-2020, 11:45 AM   #9
Charlie Stephens
Time to get out the hand crank. Worry about fixing the starter motor later if you buy it. Another topic, remember THERE IS A LOT OF WOOD IN A '29 FORDOR. If the wood is bad its costs a lot to replace it. You should add your general location to your profile, you can never tell when it will pay off.
Charlie Stephens
Old 04-10-2020, 01:37 PM   #10
ryanheacox
ryanheacox's Avatar
I remember reading something about the new switches binding. Can't remember anything more but I'll look for the thread that mentions it. Probably a Vintique part.
ryanheacox is offline   Reply With Quote
Old 04-11-2020, 09:55 AM   #11
Gary WA
Gary WA's Avatar
Thanks!
Did you get it started and then buy it??
Old 04-12-2020, 11:02 AM   #12
burner31
burner31's Avatar
My solution would be to knock a thousand dollars off the asking price
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-12-2020, 11:21 AM   #13
bobbader
Could be an early 28 starter which takes a totally different switch. If you remove the switch, there should be an insulated copper button about the diameter of a quarter protruding from the starter. It should be flat across its top and the copper should be about 1/8" thick. If, instead, the copper post is much taller than 1/8" on the front side and the top of the button looks like a ski slope (about 5/8" at highest point toward front of the car and sloping down to 1/8" in back) then the car has the earlier starter. reproduction switches for this starter are not made and you need to search for an original switch. I don't know if the newer type switch will even mount on the early starter but, if it does, there will be an immediate and constant electrical contact made which will cause the starter to run continuously once it is hooked up to a power source.
The good part is, if it has the early starter, it is easy enough to swap it for the later version and hope that that cures this and any other starting/running issues the vehicle has. If not, the "$1000 off the top of the price" is a more than viable suggestion.
Good Luck,
Bob Bader
bobbader is offline   Reply With Quote
Old 04-13-2020, 10:36 AM   #14
McMimmcs
McMimmcs's Avatar
I suggest you start it with the crank. If it starts the problem is not too serious and should not be a deal breaker. It’s likely a tinkering type of problem. Happy driving!
McMimmcs is offline   Reply With Quote
Old 04-13-2020, 02:58 PM   #15
JKY
Yes, he found a used switch that fit and worked. The new one in the parts box was junk. I bought it.
Old 04-13-2020, 02:59 PM   #16
JKY
Didn't want to buy it without running and driving it.
Old 04-13-2020, 03:31 PM   #17
JKY
Double post, sorry
