Old 11-06-2019, 03:27 PM   #1
KiWinUS
KiWinUS's Avatar
Default Source 59AB large port Intake gaskets
Guys who has best deal on large port 59AB intake gaskets.
Thanks
Old 11-06-2019, 04:01 PM   #2
Pete
Pete's Avatar
Default Re: Source 59AB large port Intake gaskets
If your ports are as big as they should be, no one makes them commercially.
Get your little gasket tapping hammer out.
Old 11-06-2019, 05:24 PM   #3
Lawrie
Lawrie's Avatar
We just made a set for the dragster eng refresh,
we got a sheet of proper material from the supplier and made them our self,my boy even cut the port holes in them on an angle so there wasn't a step.
Lawrie
Lawrie is offline   Reply With Quote
Old 11-06-2019, 07:39 PM   #4
Bored&Stroked
Bored&Stroked's Avatar
I tend to use BestGaskets - then port them with an Xacto knife . . .
Old 11-07-2019, 07:30 AM   #5
Bored&Stroked
Best Gasket Big Port intake gasket sets: 21055E (59A) - or 21046E (49-53)
https://bestgasket.com/
Old 11-07-2019, 07:35 AM   #6
uncle max
uncle max's Avatar
Arman at Best Gasket will sell you a blank gasket with the correct outside perimeter and bolt holes; then it's up to you and your knife.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 11-07-2019, 10:51 AM   #7
Ol' Ron
Ol' Ron's Avatar
What's the application of the engine? Having built a few street engines, I find the stock ports do a fine job. Compression and displacement, my 280 with EAB can is one of them.
Old 11-07-2019, 02:00 PM   #8
marko39
I have one for a 8ba build made by Best and it is already cut properly but you could trim more if needed. Got it rrom Hot Rod And Custom Supply. Price was 10.95 in 2001. Maybe I will finish engine someday.
marko39 is offline   Reply With Quote
