Old 04-28-2019, 03:02 PM   #1
Ed Pitts
Ed Pitts's Avatar
Default horn wire connection on a 1950 Ford steering wheel
Where does the horn wire connect on a 1950 Ford steering wheel. Lots of pics of the front of the wheel but have not found anything on the back side.
Thanks, Ed
Ed Pitts is offline   Reply With Quote
Old 04-29-2019, 12:40 PM   #2
leon bee
Default Re: horn wire connection on a 1950 Ford steering wheel
Bump.....somebody must know. I haven't got in there on my car yet.
leon bee is offline   Reply With Quote
Old 04-29-2019, 12:41 PM   #3
leon bee
And how did you get that alligator to stay still for the photo?
Old 04-29-2019, 08:22 PM   #4
fjz
I believe the wire goes to the horn ring.
fjz is offline   Reply With Quote
Old 04-29-2019, 09:02 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Perhaps a picture of the column end under the horn ring would help.
Don't know how the Ford is configured but on Mercury the grounding wire is connected to an insulated ring in the column that the horn ring makes contact with to activate the horn.
Old 04-30-2019, 12:41 AM   #6
FortyNiner
FortyNiner's Avatar
So, on the previous generation, the wire was connected to the horn ring with a screw and there was an insulation pad around the triangular piece shown in the first picture. Perhaps the 50s are similar.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 04-30-2019, 11:04 AM   #7
Ed Pitts
Ed Pitts's Avatar
Thanks guys. This is going on an F1 steering box and tube. I didn't know if I was missing some parts that the horn wire attached to. I'm not seeing any place on the horn ring to attach the wire and there is not a place on the inside of the wheel that looks like an attachment spot.
Old 04-30-2019, 12:43 PM   #8
34PKUP
34PKUP's Avatar
Suspect you have parts missing.
34PKUP is offline   Reply With Quote
Old 04-30-2019, 12:46 PM   #9
51 MERC-CT
51 MERC-CT's Avatar
The wire would have to be connected to an un-grounded component that is insulated from the rest of the assembly until grounded by the ring.
Old 04-30-2019, 01:07 PM   #10
41Joe
41Joe's Avatar
I found this picture online.
41Joe is offline   Reply With Quote
Old 04-30-2019, 01:23 PM   #11
FortyNiner
FortyNiner's Avatar
I'm confused. The F1 horn configuration is completely different from the car version. Are you intending to use the car ring/button on a truck column?
Old 04-30-2019, 02:00 PM   #12
rich b
rich b's Avatar
Since the wire still comes up the column shaft on a '50, you can run a '49-'50 wire up the F-1 shaft. Wonder why your horn ring does not not have a obvious screw to hook it to like in Joe's post; could it be hidden behind a different version of the insulated contact piece. You are also missing the foam rubber ring around the contact.
rich b is offline   Reply With Quote
Old 04-30-2019, 03:57 PM   #13
Ed Pitts
Ed Pitts's Avatar
Here is the underside of mine. No evidence of a missing connector. Yes, I knew I was missing the foam insulator. Usually you can see where the wire was connected, but not finding it on this one.
Yes, I knew it was different than the F1 and yes I want to use the 1950 wheel on the F1 column. As was stated, the wire for both the F! and the 1950 run up the shaft, so was not anticipating this kind of problem.
Thanks, Ed
Old 04-30-2019, 04:32 PM   #14
rich b
rich b's Avatar
Kinda of an anomaly, ain't it. Maybe just slip a ring terminal under the contact plate at one of the screws.
