Old 02-13-2021, 11:21 AM   #1
1931flathead
Default E85 fuel with a holley 94
Has anyone try to run e85 fuel on a holley 94 carb trying to find out if could happen
1931flathead is offline   Reply With Quote
Old 02-13-2021, 12:20 PM   #2
JSeery
JSeery's Avatar
Default Re: E85 fuel with a holley 94
Old 02-13-2021, 12:20 PM   #3
scicala
scicala's Avatar
The E85 will probably attack the accel pump piston (if rubber type) and the power valve diaphragm. Only designed for 10% ethanol.
A Stromberg 97 may be a better option. No rubber type parts. Just my opinion.
Sal
scicala is offline   Reply With Quote
Old 02-13-2021, 12:31 PM   #4
JSeery
JSeery's Avatar
Sal
Very good and important point Sal!!! I was just thinking about the octane.
Old 02-13-2021, 12:59 PM   #5
1931flathead
It's on a blower motor with no power valves at all compression is 9.4 and boost is around 8 to 10 with 4 of them if I'm not wrong it will be around 13 or so with boost
Old 02-13-2021, 01:16 PM   #6
tubman
tubman's Avatar
Wouldn't you have to install larger jets? When I vintage raced, the guys with midgets running alcohol just drilled them out.
Old 02-13-2021, 01:20 PM   #7
1931flathead
I was told when I was going to run gas to run 51 in all of them yes I think I need bigger ones
Old 02-13-2021, 01:36 PM   #8
tubman
tubman's Avatar
The midget guys were running almost 100% alky, and if I understand the naming conventions, "E85" is 85% alcohol. Given the circumstances, I think the proper term would be "a lot bigger".
Might be a good idea to see if there are any old-timers that ran carbs and alky back in the day. There are probably a few hiding in the weeds right here. My knowledge comes only from "bench racing", but some real serious bench racing (alcohol was involved).
Old 02-13-2021, 01:42 PM   #9
1931flathead
Don't do much good to run bigger jets if the the rest of the carb is not drilled out
Old 02-13-2021, 02:57 PM   #10
Charlie ny
Hmmm,
I build a few 94's each year and all are quite happy with e 85 or e 87.
I'm probably wrong but I thought the number was the octane not % of alky. It seems
to me (4) 94's will pass all the air a Flathead would ever need, even with a blower.
Invest in an A/F meter, run with mufflers so you can hear detonation and keep us posted.
Charlie ny
Old 02-13-2021, 03:13 PM   #11
hotrodart
hotrodart's Avatar
Charlie ny
E85 is 85% corn-gas, 15% petro-gas.....not octane rating.
hotrodart is offline   Reply With Quote
Old 02-13-2021, 03:44 PM   #12
tubman
tubman's Avatar
There is some disagreement about the exact number among the experts, but E85 has an octane rating over 100. Some late model performance freaks build their engines to use it on purpose.
Old 02-13-2021, 04:47 PM   #13
Charlie ny
Art,
Thanks for the info on e 85........our reg here (New York State) is 87 octane
unleaded which is I guess way different than e 85. What is the significance of the e
preceding the 85...never too old to learn.
Thanks,
Charlie
Old 02-13-2021, 05:48 PM   #14
1931flathead
I will have to do more checking on it
Old 02-13-2021, 07:10 PM   #15
1931flathead
On 4bbl holley they have a driffents fuel block and bigger jets and bigger needle valve 30% bigger jets size
Old 02-13-2021, 07:11 PM   #16
50fordcoupeman
50fordcoupeman's Avatar
You are exactly spot on!
50fordcoupeman is offline   Reply With Quote
Old 02-13-2021, 07:13 PM   #17
scicala
scicala's Avatar
If you run E85, I would estimate a good starting point would be main jets about 25 to 30% larger than the #51 jets. Also use a leather accelerator pump piston. This is assuming you have the power valve blocked off.
Sal
Old 02-13-2021, 09:21 PM   #18
Charlie ny
So I took a minute and googled E85.....could be as high as 105. That E makes a big difference ,not to be confused with 85 or 87 oct.
Charlie ny
Old 02-13-2021, 11:56 PM   #19
cadillac512
cadillac512's Avatar
E-85 is Ethanol-85%. That's what the "E" stands for.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 02-14-2021, 03:01 PM   #20
hotrodart
hotrodart's Avatar
Art,
Thanks,
Charlie
The "E" is for ethanol. I would bet that your 87 octane unleaded gas is E-10 (10% ethanol)......there will be a sign on the pump.....pretty much the standard blend in the U.S. east coast. The non-E fuel here is 90 octane, and costs about 20 cents more than E-10.
