Old 01-21-2021, 10:40 AM   #1
1931flathead
Default Ford holley carb fuel inlet fitting
Look for part number or if anyone has them for sale thanks
1931flathead is offline   Reply With Quote
Old 01-21-2021, 10:44 AM   #2
farmertom
Thumbs up Re: Ford holley carb fuel inlet fitting
Napa
farmertom is offline   Reply With Quote
Old 01-21-2021, 11:01 AM   #3
scicala
scicala's Avatar
Default Re: Ford holley carb fuel inlet fitting
Mike's carburetor parts has them too.
Sal
https://www.carburetor-parts.com/Bra...80_p_2408.html
scicala is offline   Reply With Quote
Old 01-21-2021, 11:43 AM   #4
1931flathead
Ok I thought they were special cause for a 94 holley carb if you look at this picture
Never to old to learn
Old 01-21-2021, 04:21 PM   #5
Ziggster
Haha! I'm glad I wasn't the only who had difficulty figuring the "mystery" Holley/Ford fitting. My saga...
https://www.fordbarn.com/forum/showt...ght=Carburetor
Ziggster is offline   Reply With Quote
Old 01-21-2021, 05:53 PM   #6
scicala
scicala's Avatar
The three fittings you posted a picture of, seal on the taper at the end like the original factory fuel line on earlier carbs. The fitting I supplied info on, seals with a fiber washer under the hex.
Sal
Old 01-22-2021, 08:42 PM   #7
1931flathead
Ok thanks
Old 01-24-2021, 04:59 PM   #8
1931flathead
Any one have a napa number the napa I have just young kids don't know what to look for thanks
Old 01-24-2021, 05:44 PM   #9
Charlie ny
These are repair fittings, upon a time easy to get NAPA etc.....not on the active here
in Buffalo N.Y. anymore. I'll buy a swap meet 94 if has that fitting on it. The fitting from Mikes is for a flare seal not a ferrule
Charlie ny
Old 01-24-2021, 06:28 PM   #10
1931flathead
Yes I need them for a 5/16 fuel line with a flare fitting just like the one in the first picture
Old 01-25-2021, 02:05 AM   #11
1941Pony
Speedway has then but they are aluminum, not brass.
1941Pony is offline   Reply With Quote
Old 01-25-2021, 06:26 AM   #12
Ziggster
If this is what you are looking for, this may help. It is from a Parker catalogue. At my local Napa store (Canada) they said they that deal with Fairview Fittings, but no matter, they should be able to cross reference it to the Parker P/N: 48IFHD-5-4
Old 01-25-2021, 06:30 AM   #13
Ziggster
Link to catalogue.
http://www.parkerstore.jp/phj/catalo..._EN/Book-E.pdf
Old 01-25-2021, 02:21 PM   #14
scicala
scicala's Avatar
The part # 48IFHD-5-4 appears to be a male 1/4 NPT thread. 1931flathead needs the male end to be a 1/2-20 straight thread.
Sal
Old 01-25-2021, 06:08 PM   #15
Ziggster
You are correct Sal. My apologies as I thought the NPT was just a reference as I know the thread for the carb is 1/2"-20. From the cross sectio pic of the fitting, it shows a straight thread and not NPT. Did some more looking and just cannot find the correct fitting, not even from the Holley website.
Old 01-25-2021, 06:24 PM   #16
Ziggster
What about is using this fitting (46F-5-4), and then inserting the one I previously mentioned? A search on this reveals all sorts of "MacGyver" solutions including retapping the 1/2"-20 straight thread to a NPT.
Old 01-25-2021, 06:39 PM   #17
scicala
scicala's Avatar
No Need for apologies. We're all just trying to help.
Sal
Old 01-25-2021, 09:44 PM   #18
1931flathead
https://www.summitracing.com/parts/edd-265500
This should be the one
Old 02-02-2021, 09:29 PM   #19
1931flathead
I found what I needed at part store if some wants the number I have it
A 5/16 brake or fuel line will screw into it
