Old 01-02-2021, 05:01 PM   #1
Thearne3
Default Remove this bolt?
I have never drilled out a bolt, but this may be the time. Someone long ago decided to replace the correct nut/bolt with this and it will not budge. The metal is too soft for visegrips and too scarred to hold any socket I can find...
It's been soaked with WD-40 for several days.
Ideas?
If drilling is the way to go, any suggestions? I don't want to drill too deep!
Thanks!
Thearne3 is offline   Reply With Quote
Old 01-02-2021, 05:10 PM   #2
Curtis in MA
Default Re: Remove this bolt?
Cut a slot in it with a dremel?
Curtis in MA is offline   Reply With Quote
Old 01-02-2021, 05:10 PM   #3
Synchro909
Synchro909's Avatar
My first attempt to remove that would be vice grips or cut a slot in it with a hack saw or angle grinder and use an impact driver on it. You might get lucky if it has been soaking for a while. If that fails, THEN you are down to drilling it out. Grind off the end so it is flat and parallel to the face, carefully mark the centre and start drilling with a small bit first and working up from there.
BTW, if you don't know how long that screw is, buy a replacement and put a tube over the drill so you can't go too deep.
Old 01-02-2021, 05:15 PM   #4
jimvette59
jimvette59's Avatar
Weld a nut on it .The heat from welding will make it easyer to back it out. JMHO
jimvette59 is offline   Reply With Quote
Old 01-02-2021, 05:19 PM   #5
McMimmcs
McMimmcs's Avatar
This procedure has worked for me on three occasions.
Old 01-02-2021, 05:27 PM   #6
Thearne3
Good ideas! I'll report back later this weekend.
Old 01-02-2021, 06:01 PM   #7
tinkirk
tinkirk's Avatar
Heat it cherry red and spray with
penetrating oil let it cool down and then try and turn it out
Will almost come out with very little trouble
tinkirk is offline   Reply With Quote
Old 01-02-2021, 07:59 PM   #8
wwirz
What is the location of the bolt?
wwirz is offline   Reply With Quote
Old 01-02-2021, 08:15 PM   #9
redmodelt
redmodelt's Avatar
What bolt is it, picture is not showing. WD-40 is not a penetrating oil, unless you buy their brand of penetrating oil. It's a water displacement (WD)/lube.
Old 01-02-2021, 08:29 PM   #10
Curtis in MA
Holds the dist in.
Old 01-02-2021, 08:49 PM   #11
FRANK PKNY
FRANK PKNY's Avatar
Find a nut that will fit over the messed up one then weld it on . when it cools it will come right out . No problem. If you don't weld find someone who can. It's an easy fix just shield the fuel tank and the like .
FRANK PKNY is offline   Reply With Quote
Old 01-03-2021, 08:18 AM   #12
David R.
Mix acetone and automatic transmission fluid about 1/2 and 1/2 and put in a pump oil can. Mix as needed as acetone tends to evaporate. Much better penetrant than the letter/number brand and cheaper. A little heat alternated with penetrant baptisms often helps.
David R. is offline   Reply With Quote
Old 01-08-2021, 10:46 AM   #13
katy
katy's Avatar
Ideas?
Thanks!
Did you get the bolt out?
Old 01-09-2021, 08:41 AM   #14
Chris in WNC
Chris in WNC's Avatar
and not much of a lube, either.
in about 30 days it will gum up like glue.....
have a couple cans in my shop but they were freebies.
I would never spend money on the stuff.
totally overrated.
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 01-09-2021, 10:33 AM   #15
hop up
hop up's Avatar
Great ideas by members but if you do chose to drill it out . I would first get the surface flat and locate center of the bolt. I would then center punch the bolt right in the center. Then drill a small hole to the length of the bolt and drill a bit larger hole. As you drill closer to the size of the bolt diameter you may loosen up the bolt to unscrew it . You can also use a center punch to push in the thread sides and get some needle nose pliers in there to unscrew the left overs. Now worse case is you drill to appropriate size 1/4-20 would be #7 drill etc and tap it out.
I would also recommend Kroil its awesome stuff and truly a rust buster
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
