11-01-2018, 08:35 PM | #1 |
Cylinder head
I have a model A cylinder head that does not have the oblong water passage in the center between cylinders 2&3. Can someone give me info on this. Should I use it? Daren
11-01-2018, 08:55 PM | #2 |
Re: Cylinder head
The oblong hole was introduced in Oct 1929.
Bob |
11-01-2018, 09:06 PM | #3 |
Re: Cylinder head
Now that raises another set of questions. I would have to assume the blocks did not have that hole also? Has anyone seen blocks without this water passage. Was the introduction of the passage because of a heating problem I would assume) and if so what kind of problem. I was told that there would be better cooling around the valves without it. Last and most important question, Should I run this head.
11-02-2018, 01:33 AM | #4 |
Re: Cylinder head
The blocks had the hole, even when the head didn't.
11-02-2018, 09:14 AM | #5 |
Re: Cylinder head
I was thinking the same but that leaves unanswered questions. Why?
11-02-2018, 09:59 AM | #6 |
Re: Cylinder head
11-02-2018, 10:31 AM | #7 |
Re: Cylinder head
11-02-2018, 05:43 PM | #8 |
Re: Cylinder head
Found some information on the early cylinder head. From what I found it is recommended that the center water passage be drilled now on to the next questions. There are two other water passages that are a different configuration that is they do not match up with the block has anyone ran this head and what can you tell me.
11-02-2018, 07:26 PM | #9 |
Re: Cylinder head
Half the Model A's build had heads without the oval center hole, and I'd never drill mine.
If you are running a B block, then there are a couple small holes that need to be plugged so you don't loose coolant into the cylinders. |
