09-22-2021, 08:13 AM | #1 |
Engine Identification '34 Ford
Hello All- I have a '34 5-Window Model B. The car is in what seems to be original condition. I am wondering how I can tell if the engine is original to the car. It is a 4-cyl engine. The VIN's all match on the rest of the car, but I cannot find anything on the engine to check it. To my understanding it is more rare to have a car with the 4-cyl engine, which makes me wonder if this is the original motor, or if it has been replaced over the course of its life. Thanks in advance!
-Greg |
09-22-2021, 08:50 AM | #2 |
Re: Engine Identification '34 Ford
I don't have the 33/34 book in front of me BUT "IF" memory serves I think the number on the fours are on the right rear of the bell housing area near where it bolts to the block OR on the right rear corner of the block??? ALSO your frame number should start differently than a V8 I believe not sure if the "AB" followed after 32. What is the starting 4 or 5 numbers??? Others more knowledgeable I'm sure will correct ME!! And, yes, the 34's with 4 cyl engines are very limited in production numbers, even more so than 1933!!!
PICTURES TOO, We love pictures!!!! Post some pictures of that "4 banger" Coupe!!! Last edited by rockfla; 09-22-2021 at 09:08 AM. |
09-22-2021, 09:39 AM | #3 |
Okay got it! I will have to check those places tonight when I get home from work. The VIN is B526****... I will attach some photos of it as well in another post!
09-22-2021, 09:49 AM | #4 |
Everything that distinguishes a '33-'34 four from a '32 four is a bolt-on part. The so-called short block (cylinder block, crankshaft, camshaft, pistons, connecting rods, etc.) is the same for all three model years' engines except for the crankshaft as only late '32 fours have a counterbalanced crankshaft.
In other words, if the engine in your '34 has a counterbalanced crankshaft, there is no way of knowing if it is the engine the car was built with or a rebuilt engine. (Obviously if it does not have a counterbalanced crankshaft, the engine is not original to the car.) Your engine number (VIN) of B526XXXX) is in the ball park, but you won't find it on the engine block but rather on top of the flywheel housing which is a bolt-on component and may or may not be attached to the original engine block. You're correct, '34 fours are rare as Ford stopped offering them in its U.S. cars, commercial vehicles, and trucks in April, 1934 as the demand for them keep declining throughout the '33 model year and into the '34 model year. I once had a four-cylinder '34 roadster and presently have a '33 four-banger coupe. Last edited by DavidG; 09-22-2021 at 09:54 AM. |
09-22-2021, 09:53 AM | #5 |
Last edited by GThorpe; 09-22-2021 at 09:53 AM. Reason: link did not include photo |
09-22-2021, 09:54 AM | #6 | |
09-22-2021, 10:21 AM | #7 | |
09-22-2021, 11:23 AM | #8 |
IF you look at the "dash board" of the box you posted in, there is a black paper clip in the top center. Click on the black paper clip and you will have a box with about 6 lines where you can upload pictures from your computer. Be mindful that you cannot load "large" megabite pictures SO you need to make sure the file size is below Like 1G.
09-22-2021, 11:38 AM | #9 | |
09-22-2021, 11:42 AM | #10 |
Wow, that's one sweet looking ride!!!! Thanks for sharing. THE "OTHER" contributing factor that is in NO books OR doesn't get mentioned IS.......How many people acquired a car like yours and "Converted" it to a V8. SO "HOPEFULLY" yours doesn't ever meet that fate!
09-22-2021, 11:55 AM | #11 |
x2 Keep it as is!
09-22-2021, 12:09 PM | #12 | |
09-22-2021, 12:13 PM | #13 | |
09-22-2021, 12:15 PM | #14 | |
AND....Is it me OR it looks as if you are missing a (1) horn???? Can't see from the shadows |
09-22-2021, 12:20 PM | #15 | |
09-22-2021, 12:21 PM | #16 |
Correct 1934 Ford Hubcap >
Looks as though GThorpe has '32 Hubcaps on his car >
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 09-22-2021 at 12:31 PM. |
09-22-2021, 12:32 PM | #17 |
09-22-2021, 12:39 PM | #18 |
NO V8 Caps, I am scrambling to find a better picture BUT here is a 34 Roadster with a 4 cyl that has the "Ford" oval hub caps, one feature line near the outer edge of the cap, Ford Oval in the center, close to the upper of the two caps posted by petehoovie BUT with the Script Ford Oval instead!!!!
09-22-2021, 12:45 PM | #19 | |
09-22-2021, 12:53 PM | #20 |
Here you go
