08-13-2021, 05:41 PM | #1 |
Wheel nuts
Ford Barn has posted a warning earlier, do not use repro' wheel nuts, I found it out the hard way last week. Left rear wheel fell off, all my repro' nuts gone, put it back on, a big mistake since the holes were worn, it fell off AGAIN as we neared home.
I've since bought a good wheel, also a good used hub/drum, that was a hundred bucks, also a dozen original Ford nuts on eBay, another 40 bucks. My advice: Do NOT use these repro' nuts, they are not recessed to accommodate the nub on those studs, stud threads do no go all the way to the drum, your wheels will not be tight, even tho' your nuts seem tight. I'm not the first one to have this happen, don't be the next, find and use only genuine Ford wheel nuts, toss those repro's in the junk. Warrene |
08-13-2021, 07:05 PM | #2 |
Re: Wheel nuts
Where did you get the nuts from and what was the finish?
"The more things change, the more they stay the same." |
08-13-2021, 07:53 PM | #3 |
Re: Wheel nuts
Henry warned us 100 years ago about "gyp" parts. Still true today.
08-13-2021, 10:36 PM | #4 |
Re: Wheel nuts
Thanks for the reminder to check before installing. Those lug nuts have been kicking around for many years.
08-14-2021, 03:43 AM | #5 |
Re: Wheel nuts
Can someone post a picture please of the quality ones and the inferior ones side by side so we know how to distinguish the ones to avoid.
08-14-2021, 11:22 AM | #6 |
Re: Wheel nuts
08-14-2021, 12:50 PM | #7 | |
Re: Wheel nuts
I wish the Model A parts suppliers would have a picture showing the threaded end of the lug nuts, the insides. Here is an illustration from The Model A Ford Garage showing the difference between GOOD lug nuts and the ones that should be tossed in the trash as warren stated that he ran into on his car. http://www.fordgarage.com/pages/dangerouslugnuts.htm |
08-14-2021, 01:58 PM | #8 |
Re: Wheel nuts
Keep in mind Vince's article is from 2002 - a lot of things have changed since then.
08-14-2021, 09:49 PM | #9 |
Re: Wheel nuts
08-15-2021, 01:11 AM | #10 |
Re: Wheel nuts
The problem goes back to 1988. This article appeared in the Restorer.
Tom Endy |
08-15-2021, 06:22 AM | #11 |
Re: Wheel nuts
In my opinion, besides using the correct nut, the combination hand crank and wheel nut tool does not allow enough torque on the nuts. I carry a breaker bar, extension, and socket in my car to tighten (and untighten) the nuts. I have had wheels come off of two modern cars after new tires were put on because the nuts were not tightened correctly by the tire shop.
08-15-2021, 08:48 AM | #12 | |
Re: Wheel nuts
Not my birthday lol but thanks anyway!
08-15-2021, 03:40 PM | #13 |
Re: Wheel nuts
I haven't had any problems with my new lug nuts, but I did notice the studs when pressed into new cast iron drums, didn't have threads going all the way down to the drum. This could cause the nut running out of thread before tightening the wheel to the drum.
08-15-2021, 04:01 PM | #14 |
Re: Wheel nuts
Warrene : Could you post some pictures of the original and the bad ones, so we can see the differences?
08-16-2021, 08:25 AM | #15 | |
Re: Wheel nuts
People are still re-selling these dangerous parts today and many still remain installed on cars. Which is one of many reasons to not buy parts from places such as Ebay or Swap meets The damage is still being done today. The good thing that has happened since 2002 is that hopefully some folks have read Vince's page and did destroy some of the bad parts. The only way to get rid of these parts is for individuals to find these parts and destroy them. Twenty years does not change these facts. The purpose of Vince's article is to rid the world of these parts. There is nothing to prevent a crook from selling his junk repro wheel nuts on Ebay and calling them New Old Stock or Genuine Ford parts. Last edited by Benson; 09-22-2021 at 03:56 PM. |
08-16-2021, 09:56 AM | #16 | |
Re: Wheel nuts
08-16-2021, 07:39 PM | #17 |
Re: Wheel nuts
If they are dangerous why are the vendors selling them?
08-16-2021, 07:54 PM | #18 |
Re: Wheel nuts
No one has said specifically that any bad nuts are being sold currently.
08-16-2021, 09:35 PM | #19 |
Re: Wheel nuts
Thanks guys for the info and "heads - up" on the bad nuts. I had replaced my old originals a few years back with the cad plated ones from Snyders. I went out and checked them today, looks A- OK , nice counterbore and deep cut thread. You can tell from the feel on the wrench that the nut is binding down on the wheel hub rather that bottoming on the stud shoulder.
Joe B |
