Old 08-07-2021, 11:31 AM   #1
DBrer
Default stripped nut
One of the little nuts that holds the dash panel is stripped. Any ideas on a fix? Should I go to a 12x24 machine screw? I think the orginal is a 10x32.
DBrer is offline   Reply With Quote
Old 08-07-2021, 11:45 AM   #2
Merc Cruzer
Merc Cruzer's Avatar
Default Re: stripped nut
Put a small piece of wire through the hole in the nut and then screw it bask on. Temporary fix, but it usually works.
Merc Cruzer is offline   Reply With Quote
Old 08-07-2021, 11:54 AM   #3
Patrick L.
Patrick L.'s Avatar
One of those temporary fixes that lasts a lifetime.
Old 08-07-2021, 07:52 PM   #4
DBrer
Thanks for the info, I retapped it and it works fine now.
Old 08-07-2021, 08:06 PM   #5
Merc Cruzer
Or you could just re-tap it.
Good to hear you found a solution.
Old 08-08-2021, 05:23 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I know you fixed it. A handy tool is the thread repair tap and die set. It cleans the threads without taking much metal off. After I bought a set, I wondered how I managed without it.
Old 08-09-2021, 03:02 PM   #7
Superhart
Superhart's Avatar
Another idea is to use a small amount of 0000 steel wool in the hole with a toothpick and then reuse the original screw. I actually saw a dash screw attached using a wing nut. To access the wig nut you swing out the windshield. Kinda "screwy" but effective.
Superhart is offline   Reply With Quote
Old 08-09-2021, 04:00 PM   #8
Merc Cruzer
Thanks, I will remember the steel wool the next time.
