Old 09-23-2021, 11:58 AM   #41
GThorpe
Default Re: Engine Identification '34 Ford
Originally Posted by DavidG View Post
Today might be your lucky day as I have a spare set of NOS '34-only four-cylinder hub caps as in Robert's photo above (but with the blue paint intact). Please send me a p.m. if you are interested.
Back on Robert's post #10, I could ring the neck of the guy that I sold my four-banger '34 roadster to as while he restored the car, he did so as a V8.
When you get a chance, I very much would like to see your engine compartment; both sides, please.
Here's a few photos of the engine compartment you asked for. Let me know if there is anything you'd like to see in better detail. FORD1.jpg
GThorpe is offline   Reply With Quote
Old 09-23-2021, 12:25 PM   #42
DavidG
DavidG's Avatar
Thanks for the informative photos.
With the notable exceptions of the horn, ignition coil, and carburetor, everything looks to be of Ford origin. One Ford item that has been replaced over the years with an earlier version is the generator. It has what appears to be a '32 generator with a stamped steel front cover/support instead of the late '33-'34 version with a die cast front cover and a vented back cover.
I assume that your wanted list includes an air cleaner with a modern element as running it without one will hasten the time when the engine will require rebuiding.
Old 09-23-2021, 02:53 PM   #43
petehoovie
petehoovie's Avatar
Old 09-23-2021, 04:45 PM   #44
rockfla
rockfla's Avatar
Once again, IF “authenticity” and “as Henry built it” the ultimate goal, you are also missing engine tins/splash aprons pictured. Not uncommon them
missing, most don’t know as they aren’t there to begin.
File Type: jpeg 000E9657-9584-4660-83E0-1FBC7F11CFED.jpeg (108.1 KB, 10 views)
File Type: jpeg 0DE27BE8-9B82-4FF0-B2B9-DA4AE50D2AB0.jpeg (112.3 KB, 7 views)
Old 09-24-2021, 06:32 AM   #45
rockfla
rockfla's Avatar
I stand corrected, DavidR astutely pointed out...my quick glance at the left side shows your tin appears bent downward. Your right pan is clearly there. my apologies on that detail
