Old 09-19-2021, 09:36 PM   #1
MickyD
MickyD's Avatar
Default Door hinge screw removal
I need to replace the lower passenger door hinge on my 28 roadster. I can't seem to be able to remove the screws no matter what I do. Any ideas would be helpful. So far I have WD 40 them with no results. I really don't want to drill them out.
MickyD is offline   Reply With Quote
Old 09-20-2021, 01:44 AM   #2
aermotor
Default Re: Door hinge screw removal
Blaster and air impact wrench with the tightest fit bit you can get.
John
aermotor is offline   Reply With Quote
Old 09-20-2021, 01:51 AM   #3
redmodelt
redmodelt's Avatar
Grind your bit to fit the slot with flats along the sides, not tapered. WD-40, the normal stuff is not penetrating fluid. Kroll works good too.
Old 09-20-2021, 02:26 AM   #4
Oldbluoval
Oldbluoval's Avatar
The above are spot on suggestions
Best not to drill. It could leave part of the screw protruding on the back side and not let the hinge come forward to remove. Only solution then is drill bigger!
Is the car painted? If not a little torch heat could help
Old 09-20-2021, 04:07 AM   #5
mercman from oz
mercman from oz's Avatar
Good illustration of how important it is to use the correct tool for the job.
Old 09-20-2021, 04:49 AM   #6
Stingray70
Stingray70's Avatar
I bought a large "gunsmithing bit" set on Amazon. At least a dozen different hollow ground bit sizes. I never knew there were so many... I have used this set while working on the A several times. Unfortunately they are not strong enough to use in an impact driver.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 09-20-2021, 11:45 AM   #7
Bob C
An impact driver works good also.
Old 09-20-2021, 02:58 PM   #8
51504bat
51504bat's Avatar
This from Eastwood:
https://www.eastwood.com/eastwood-sc...=google&wv=3.1
Old 09-20-2021, 03:05 PM   #9
electricman
I have found that peening the tip of the blade to fit snugly into the bottom of the slot grabs at the base of the slot better so the driver has less of a chance of rolling out of the groove when torqued. Good luck
electricman is offline   Reply With Quote
Old 09-20-2021, 03:58 PM   #10
MickyD
MickyD's Avatar
I am getting it ready for the paint shop. The hinges are the only thing to come off right now..
Old 09-20-2021, 06:21 PM   #11
d.
try some heat and then touch it with candle wax. A light "rattle" with an impact gun set low might help also. be sure the bit fits tight.
d. is offline   Reply With Quote
Old 09-20-2021, 06:57 PM   #12
ericr
ericr's Avatar
roger that, we had a big to-do about WD-40 previously. The "WD" stands for water displacement. As I recall today, it was a product that came out of the space program in the 1960s for some purpose therein. Back then it was generally assumed by the public to be some miracle deruster/lubricant, which it was not.
ericr is offline   Reply With Quote
Old 09-22-2021, 05:48 PM   #13
Ted Duke
This WD-40 product works.
WD-40 SPECIALIST
Rust Release Penetrant, Aerosol, 11 Oz.
Ted Duke is offline   Reply With Quote
Old 09-22-2021, 05:51 PM   #14
51504bat
51504bat's Avatar
50/50 mix ATF and acetone
Old 09-26-2021, 02:07 PM   #15
dkibby
dkibby's Avatar
I had to resort to welding a bolt to the screw head to get enough torque to remove them. Impact driver worked on a couple.
dkibby is offline   Reply With Quote
Old 09-26-2021, 02:36 PM   #16
Gene F
Gene F's Avatar
Sometimes a square shanked screwdriver is nice cause you can lean in on it, while a buddy puts a wrench on it.
Old 09-26-2021, 02:51 PM   #17
john charlton
john charlton's Avatar
This has worked for me with very crusty door hinge screws . I assume you are not concerned about paint at this time . Heat the screw head very hot but not yet cherry dowse it with cold wter . Use a good quality impact driver and a snug fitting bit . A few hefty bops should free it .
John in Suffolk County England ,
Old 09-26-2021, 06:17 PM   #18
Ruth
I agree. I have had excellent results using an impact driver. Get a good one, not a cheapie. And as suggested, get bits that fit.
Ruth
