08-30-2021, 10:03 AM | #1 |
Surface Rust in Coolant Passages.
There is surface rust in the engine coolant passages in my 29 Special Coupe. The rust in the photo looks worse than it really is. I poked my finger into the holes and was able to almost wipe it off. I did not see any scaling or blocked passages in the block, and I imagine that things are okay below where I can't see.
My question is, is this something that I need to address now or should I wait and treat things after I get the head back on and things buttoned up? What would be the best way to address this? Also, there are some minor scratches on the block. How should I addressed those? Bill Last edited by philcobill; 08-30-2021 at 10:25 AM. |
08-30-2021, 10:58 AM | #2 |
Re: Surface Rust in Coolant Passages.
Flush it and forget it, not that bad
08-30-2021, 11:03 AM | #3 |
Address it after the system is sealed, using a de-rusting product like Thermocure or Rust911. Users of this forum have reported success with both; just follow the directions.
08-30-2021, 05:09 PM | #4 |
Surface Rust in Coolant Passages. |
08-30-2021, 09:43 PM | #5 |
Turn it upside down and blow out the junk shown in the picture.
08-31-2021, 01:40 AM | #6 |
08-31-2021, 06:35 AM | #7 |
The rust you see is normal.
Bob Bidonde |
08-31-2021, 11:44 AM | #8 |
I think if you run some flex cable thru the passages you can, you’ll have more than surface rust coming out.
08-31-2021, 09:01 PM | #9 |
Run 50/50 anti freeze and this will not happen on the future
09-02-2021, 09:49 PM | #10 |
09-02-2021, 10:04 PM | #11 |
Not a problem. Run anti freeze or rust inhibitor.
