Old 01-12-2021, 09:23 AM   #1
Mike34
Mike34's Avatar
Default 1933-34 Speedometer Gear Case
I have a new set of 3.54 gears installed in my '34 axle. I need to swap out the drive gear (to 18 teeth.) I was looking at MACs which has the parts but I noticed that they offer the same gear case housing for both the Model A and 32-48 cars. I thought that there was a difference in the gear case housings for the Model A vs. Flathead years. Are they truly the same housing?
Thanks,
-Mike
Mike34 is offline   Reply With Quote
Old 01-12-2021, 11:41 AM   #2
jetmek
Default Re: 1933-34 Speedometer Gear Case
I think the differences are the case thickness is different depending on ratio to mesh properly with the drive gear on driveshaft
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 01-12-2021, 12:09 PM   #3
Mike34
Mike34's Avatar
Case thickness or gear diameter is what is different? I always thought that it was the gear diameter, which is based on the number of teeth (18, 19, 20) which would affect the diameter of the gear. Thus, you used thicker/thinner or multiple gaskets to ensure proper meshing of the gear.
I thought that I read a post (a while back) that said the diameter of the driveshaft tube was different, therefore the curvature (radius) cut of the gear case was different.
Old 01-12-2021, 12:36 PM   #4
DavidG
DavidG's Avatar
The gear cases are the same 1930-34+.
Old 01-13-2021, 07:56 PM   #5
Andy
I have an 18 tooth (3.54) case and a shaft. The gears and other parts available I think. $15?
Andy is offline   Reply With Quote
Old 01-14-2021, 11:23 AM   #6
jetmek
On every 354 gear swap ive done it was necessary to sand the curved area to get the gears to mesh due to the smaller dia of the driven gear. Think about it. When you change to a smaller gear the center lines have to move closer for the teeth to mesh
Old 01-14-2021, 12:32 PM   #7
35fordtn
35fordtn's Avatar
We offer them for the square shaft (1930-48)
https://thirdgenauto.com/product/new...ly-3-54-ratio/
You can use a 18 gear in a 19 case but not a 21 case (without some modification)
35fordtn is offline   Reply With Quote
